Question about LG DLE5977 Electric Dryer
The dryer is not heating up or drying clothes. I read another person said it might be a burnt out heat element. How would we check for this.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 289 Answers
Turn off the power and or unplug the drier. Remove the back panel and you should see the heating element wires. Disconect them and with a digital multimeter set on resistance touch each lead the red and the black to the ends of each element. ( there maybe only 1 element so thats two ends. If you measure zero resistance then the element is shot.( shorted out ). if the meter reads 0.0 ohms then the element is blown open. You should get some resistance.
Posted on Sep 29, 2010
  • 51 Answers
With no heat comes no dry clothing. The heating element is not coming on, it could be the thermo cutoff(fuse) is burned out, that is alot less $ than the heater. You will need to check with a ohm meter, pull up veiw of part location by use of model# on any parts web page.
No heat/Only works on one setting
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 08, 2012 | Roper Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Clothes dryer doesn't heat
Nov 26, 2011 | KitchenAid Dryers
My kenmore dryer runs but not drying and no heat.plz let me know waht i should do?
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore 63942 Dryer
Dryer has warmth but clothes are not drying. vent is not clogged, temp set at regular,drum is turning What could be the Problem?
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 25, 2010 | Maytag PYE2300AY Electric Dryer
The dryer is not heating to dry the cloths.
Hi
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 20, 2010 | Dryers
Appears to be working but not drying clothes
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
Gas Dryer---
Hope this helps...
Daniel
Sep 02, 2010 | LG Dryers
Dryer has some heat but is taking a long time to dry clothes
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer wont dry my clothes
Your heating element is not working. The element could be burnt out or the high temperature switch is bad.
May 29, 2009 | Dryers
Heating good, venting good but takes two or three times to dry clothes
sounds like theres a burnt link on your elements,if for example you have a 2000watt dryer you should be getting 9amp for 220v supply 18amp for 110v supply,watts =voltsxamps,amp clamp the feed wire to check,if you have a half heat switch that could also be problem,ask a competent electrician to do the above checks,hope this helps
May 10, 2009 | Dryers
LG DLE5977 Electric Dryer Logo
120 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
