Question about Canon Pixma iP6600D InkJet Photo Printer
Won't load paper
All software is intstalled. I initialize printer to begin printing, it appears to be loadinging paper, but paper crumples up and doesn't get fed into print carrier.
  • mpblake Sep 14, 2008
    when i try to print something the front right of the paper folds. this forces the left side to get chewed up. then the printer either spits out the mangled paper or it jams.
    HELP !!!!!!!
    Problem Solver:
  • 18 Answers
This printer needs to be maintenanced. Either with your maintenance program found in Properties or taken and cleaned physically with isopropyl alcohol.
Terry
Posted on May 26, 2008
I have a paper jam and I can't locate the problem. I accidently loaded the printer with paper not knowing that several sheets had been stapled together. I removed the jammed paper but it still keeps...
  1. Turn the printer off and unplug the printer from the A/C outlet.
  2. Open the printer and check the paper path for a paper jam or misfeed.
  3. When the paper appears as crumpled or waded up, carefully remove all the jammed paper.
  4. When the paper appears to be angled incorrectly, it may be misfeeding through the printer, remove the sheet of paper.
    • Remove the paper stock and reinsert the paper, make sure the paper guides are adjusted correctly.
  5. Close the printer cover(s).
  6. Plug the printer into the A/C outlet.
  7. Turn the printer back on.
  8. Resend the print job.
  9. In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Dell Printer Support
Feb 26, 2014 | Dell 3110cn Laser Printer
Lexmark Prevail Pro705 printer jams each attempt to print. Reasonably new, Lexmark just replaced printhead and ink cartridges under warranty and printer gave better print results than when brand new. Joy...
Make sure your printer is updated. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update on your computer. The update will make your printer more reliable and more efficient.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 13, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Printer prints but crumples paper
I guess you have a roblem in your fuer assembly, replace it
Apr 07, 2010 | HP LaserJet 1300 Printer
I C309 printer not pulling paper correctly every time and crumple
HEY YO! THIS IS A CAR(YOU KNOW AUTOMOBILE)FORUM,NOT COMPUTERS FOR DUMMIES!!!!!!DUH!!!!
Dec 18, 2009 | 1996 Chevrolet Cavalier
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
Jul 21, 2009 | Office Equipment & Supplies
PAPER WON"T LOAD
The problem is software rather than mechanical operation. Uninstall the printer driver from the Add/Remove section of the Control Panel. Pull out the USB port and replace it back. This will prompt you pc to install the driver of the newly found hardware. Reinstall the printer driver. Should your printer be observed to have the usual problem, replace both cartridges with a one. "Loading paper" problem feedback is the same prompt as what you get when cartridges are old or refilled with unauthentic ink.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
HP Laserjet 3050 paper jam
The rollers may be worn so it is not getting picked up evenly. Also, be sure that your paper tray in aligned properlyand guides are keeping the paper straight. If both of these seems to be good then there may be something in the paper path.
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
Crumpled paper comes out of copy machine
Firstly make sure that in the cassette the paper tray guides are fully against the paper as if they are not the paper will wiggle through the machine and cause your fault. If this doesn't work then check the paper path as there maybe a small piece of paper causing it to shift and turn causing the crumple. Also check the fuser and the little plastic stripper fins as they may have dried toner on them causing the fault.
Hope this helps you
Thanks J
Jan 08, 2008 | Office Equipment & Supplies
Crumpled pages
Damp paper is a common cause (concerina in fuser assy) as is lower heat roller being wrinkled (orange roller in rear)
Dec 31, 2007 | Brother HL-2040 Laser Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
77 people viewed this question
old marine
old marine
