Just want to know how to get to the convergence menu on a RCA p52937 projection tv?
  • 130 Answers
Hi
the convergence menu is not available for you
but it is for technician in the service menu I would not suggest to do it yourself unless you have previous expérience
Posted on Sep 29, 2010
Colors dont line up
This is a common issue with Rear Projection TV's, especially after they have been transported or knocked.
You need to carry out a procedure called: CONVERGENCE
Go into your tv's menu and there should be a Convergence option.
Follow the instructions and it will show you how to line up the RED, GREEN & BLUE lines together. Save your settings before exiting the menu.
If done accurately, your picture should improve dramatically.
Cheers,
"If this has helped your solve your problem, please rate this solution with thumbs up"
Jun 16, 2011 | RCA P52937 52" Rear Projection Television
Concave picture
the convergence power supply module has failed
if you go into the menu you will not find convergence adjustments in the menu
the power supply module can be repaired
or you may want to get local help
if you want to try to repair you can get parts at mcm or encompas or tvrepairworld.com
Oct 26, 2009 | RCA P52937 52" Rear Projection Television
Hi RCA 52 inch part numbers P52937SG
Tries this website for convergence ICS.Must know how to solder?Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA P52937 52" Rear Projection Television
Same problem, only with RCA model P61926
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 27, 2009 | RCA P52937 52" Rear Projection Television
Tv help!!
ALright. you might have a simple inexpesive problem...MIght... first question If you go into setup menu do you have convergence option.. if you dont this it is a small special fuse that blows because of bad connections... can you solder electronic components. the parts about 5 bucks and takes less than 30 min to replace. Let me know if this is the case.
May 15, 2008 | RCA P52937 52" Rear Projection Television
RCA R52WH77 convergence missing from menu
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
Apr 08, 2008 | RCA P52937 52" Rear Projection Television
Convergence problem
If the set is a ptk 195 chassis,check your menu in screens to see if the adj. projection tv is there,if not the convergence power supply is bad.
Feb 23, 2008 | RCA P52937 52" Rear Projection Television
Rca p2937sg convergence
He could need the orginal remote or atleast one that is close to get in the service menu for this set. If you did not have the remote or he didnt know how to get into the service menu this could be true.
Jan 14, 2008 | RCA P52937 52" Rear Projection Television
RCA Projection TV model #p61926
get an estimate to fix your convergence problem
Oct 08, 2007 | RCA P52937 52" Rear Projection Television
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
