Question about Dell E172FP 17" LCD Flat Panel Monitor
My computer is on and everything is plugged in but my monitor will not turn on. I have done everything I can think of and still nothing.
  • 11,361 Answers
Louie is correct, this monitor is OLD. If you want to DIY repair, them please read an look at the pictures:
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Sep 29, 2010
  • 732 Answers
Camariqqic, Your E172FP is older than dirt!!! Look at the "date of manufacture" on rear of unit. If unit is connected to a "live" 120v ac outlet, it should work. If E172 had a nice bright, clear and crisp display of text and graphics you may need to visit YOUTUBE for some video clips that will show you how to disassemble, inspect and possibly DIY repair the unit so you can get 1-3 more years service out of it. Do your research here at fixya and follow all links you find in the profiles of "budmrtn" "buddymc" "12fixlouie" If you deem unit as too old, and your really not into the soldering of parts to printed circuit boards, then just buy new 16 x 9 wide screen unit. Let us tech's here at fixya know what your intentions are??? 12fixlouie
My computer turns on, i can hear it, but the monitor displays "no signal"
Because you are getting no signal on monitor, The first check would be the VGA cable! Do you have a spare to test with?
Jan 18, 2015 | AMD Computers & Internet
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur BP....it;s not worth this much effort....
the kind of work u have done...it seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | Computers & Internet
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Monitor rejects computer
I'm just guessing, but it could be that the resolution you are using on your MS-DOS monitor is not compliant with the new monitor you are trying to use. Check the supported resolutions of the monitor that you would like to use, and then make sure you set that resolution before switching monitors.
May 10, 2009 | Computers & Internet
Monitor turning black
the backlight fluorescent bulb is burned out.
Dec 26, 2008 | Computers & Internet
Monitor
I think your resolution is set too high reduce it in safe mode
Sep 02, 2008 | Dell E153FP 15" LCD Monitor
Hannspree HF229H
I think that you have multiple displays enabled through your video card. Just disable multiple displays.
Aug 16, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Monitor keeps saying self test everything working check plugs
The self test thinks nothing is connected to it
it might be the cable or the input circuit.
not an easy issue to verify if you only have one input.
most often its is the internal board with a failed input circuit.
you can only open the unit and test the vga cable continuity.
as most have a 1 year warranty you might want to check on yours.
Nov 13, 2007 | Acer AL1912 19" LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
