Question about Sony KP-61V85 61" Rear Projection Television
I have a Sony color rear projector video projector KP-61V80 television, manufactured in October 1999. The TV screen went blank and while you can see that it is powered on, the timer/standby light is solid black. I've changed electrical outlets, tested outlets, unplugged, powered off overnight, and nothing seems to help or change. I've also tried to hard reset and hold the "power" button down for a minute to no avail. This happened yesterday evening and it was very warm outside. Could this have played any role in the malfunction? Any info you can provide is greatly appreciated. Sony seems to be stumped. Thanks, Jen
  • Kim Yearick
    Kim Yearick Sep 29, 2010
    Is there any sound? What do you see that makes you say that it is powered on? This unit has CRTs. While they usually have a blinking standby light if the power supply is ok you say that yours does not. Answer these questions and I can probably help solve your problem.
    Thanks for using FixYa.
    hardrocko
  • jngevas Oct 01, 2010
    No, there is no actual sound or noise coming from the speakers however when the unit is unplugged from the wall, the timer/standby light is not lit. When I plug the unit into the wall, you can hear two brief clicks and the timer/standby light flashes once then turns solid red and does not change. No other noise or changes whatsoever until I unplug and plug in again. I assumed that with the that brief clicking noise and the light being solid red, the unit was powered on? But I have NO clue?!? BTW, what's a CRT? Thanks so much for your help! =)
  • 130 Answers
Hi
your problem is kind of general type it could go from a fuse to important components
it would need much more investigation
Posted on Sep 29, 2010
  • Kim Yearick
    Kim Yearick Oct 02, 2010
    jngevas,
    Thanks for the extra information. CRTs are the conventional tubes used in TVs. Yours has 3. A red, green and blue CRT. They are run very hard to produce enough light to make a good picture. This generates alot of heat and will destroy the components sooner than a conventional direct view unit.
    From the additional information you supplied I would say that you have a bad high voltage section. This is very common with older TVs of any brand. The description of how your unit starts up is a classic symtom of a blown Horizontal Output Transistor due to a shorted or partially shorted flyback. If you do not know what CRTs are you are not going to be able to identify these components and replace them, but you probably can replace the entire board. These days boards are not that expensive.
    There are several ways you can approach this. I have a tip athttp://www.fixya.com/support/r4916851-di... which should walk you through the process and get your unit fixed.
    Thanks for using FixYa and for the great rating.
    hardrocko
I need a manual to fix my 1997 Sony Color Rear Video Projector, model #KP-41T35, i think i need a ballast.
Very old set and many parts for it are no longer available.
Set does not have a Ballast.
Apr 20, 2012 | Televison & Video
Kp-61v80 will not come out of split screen
Do you have tv original remote?
TV remote will work to cancel split screen function.
Thanks.
Jul 09, 2011 | Sony KP-61V85 61" Rear Projection...
Sony KP-53V25 Color Rear Video Projector Powering off unexpected
possible crt problem, they have to be reseated, if not then the convergence is failing expect to pay around $300-350
Jul 26, 2009 | Televison & Video
Cracked outer screen on projection tv
No it can't be repair only replaced.
Part# 4-090-943-01 $76.15
Freight charges may range from $45 - $150
Jun 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Stand-by light flashes 4 times and blank screen/no vid or aud
replace q502 a T504
H.O.T/ and flyback.
parts cost and labor should be about $190
Jan 07, 2009 | Sony KP-61V80 TV
Replacement Screen for 65 " Sony Color Rear Video Projector
Try HERE to get replacement screen for your TV.
Good Luck.
Sep 26, 2008 | JVC AV-48WP30 48" Rear Projection...
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Jul 23, 2008 | Sony KP-61V45 61" Rear Projection...
Tv went blank
Does the timer/stand-by light blink at all? If so, count how many times it does. It will usually be in intervals. If it isn't blinking, and you have nothing on the screen, you might have a problem with the "G" Board, part # A1316499A.
C-Dog
Dec 16, 2007 | Sony KP-61V90 61" Rear Projection...
Sony KP-61V85 61" Rear Projection Television Logo
259 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
