Question about Casio Watches
How do i adjust the band on my casio edata bank watch?
  • 4 Answers
Http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Posted on Sep 29, 2010
How do I adjust the band on a Casio AQ 160 watch?
try this link below there are several diffarant band adjustments that may help you
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Nov 02, 2012 | Casio Watches
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    How do you adjust the band?
    Read my tips and tricks. Watch band is called bracelet as well.
    Jan 23, 2010 | Casio Wave Ceptor Atomic WV300DA 7A...
    I need to shorten the metal link watch band of my Casio Model 2747 watch.
    I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
    I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
    Thanks,
    Steve Zansler
    Dec 31, 2009 | Casio Watches
    Adjust-a-Casio-S-1087DY-Watch-Band
    On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
    http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
    which should help you to remove the link pins safely without scratching.
    Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
    Adjust the band links for Casio MTP4500D-1AV ( model #4755 )
    You can tap out the pins in the band with a small punch. a ground off needle may do it
    Jun 22, 2009 | Casio MTP4500D 1AV Analog with Chronograph...
    Casio G-Shock G-7100D 200m eData
    I suspect the battery is dead. This watch needs a CR2025 battery.
    Jul 17, 2017 | Casio G-Shock G7100D-1V Wrist Watch
    Band size adjustment
    Try entering Casio`s page and search the manual.
    Jul 29, 2008 | Casio AW80-7AV Wrist Watch
    Casio watch band adjustment
    Check the Citizen web site: http://www.citizenwatch.com/Technical/English/Service/pin1tube.pdf
    You can skip the part about removing the split tube. Instead of their pin pushing tool, I used a short piece of straight pin held with long-nose pliers while I squeezed using medium sized channel-lock pliers. A helper to hold the watch would've been good.
    Jun 30, 2008 | Watches
    Watches Logo
    85 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
