Question about Movado Museum Esperanza 604122 Wrist Watch
What if my small slide over the battery has come off completely? how do i put it back?
  • 4 Answers
It should slide into/under a slot from the side, and be held in place by tension (not familiar with the exact model, so bear with me...). Some covers are held in place with a screw; you'll know this is the case if one end has a hole in it. Eyeglass screw kits are a good source for tiny screws. Hope this helps!
Posted on Sep 29, 2010
Testimonial: "Thank you, yes i saw the screw, i just put the piece in their for now without screwing it, but the watch isnt working, it must need that for a ground "
How do I change my battery in my nixon 51-30chrono stainless watch
Where the back contacts the watch you'll discover a spot where the back doesn't completely contact the watch case. Slide a thin bladed knife in there to pry off the back. You may see a screw holding the battery down. A jewelers screw driver will be needed to loosen it. You will see a number on the battery. The replacement battery will have the same number on it or a series of numbers it's compatible with. Once the battery is out, replacing it is simple.
Jan 01, 2016 | Nixon Watches
How to change slap watch battery
On the back plate is a little slot on the side. It's very small so hard to find. You can slide a little screwdriver into that slot and pry the back plate off.
Jul 19, 2012 | Watches
How do you change the battery?
Most digital watches have screws holding the back on, you will have to get a mini phillips screwdriver available in most stores. Remove all four screws, inside there will be a plate over the battery this plate may come up one of two ways, a screw which will require a regular screwdriver not phillips but still very small or the other way is the small metal plate has a tab you lift up you will need a magnifier to see this tab, once you pop it up batter will slide out. The battery will probably be a lithium style battery available at most stores. NOTE: there may be more than one screw that has to be removed on battery plate and sometimes you have to remove one side of watchband to get back off!
Aug 27, 2011 | Nike ACG Ascent WA0008 wristwatch
I have a pocket watch i bought in paris but the battery ranout and i cant get the back off to get the battery out. what should i do?
Hi Josh, I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
  1. Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
    (OR)
    Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
  2. Remove the circular watch battery out of the back of the watch.
  3. Take the battery to any department store or watch store and purchase a new replacement battery.
  4. Insert the new battery into the back of the watch.
  5. Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
Nov 12, 2010 | Fossil VT2654 Pocketwatch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Hello, I just bought a Timex Acqua with Indiglo
    Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
    Aug 18, 2010 | Timex 2J611 Watch
    I want to change out batteries
    1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
    2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
    3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
    THANK YOU FOR VISITING FIXYA
    Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
    How do I replace the battery in my timex Expedition indiglo watch? There's a metal bracket that has clips on either side that appears to be holding it down. How do I unclip it? handyman
    mcdevito75 here, Without seeing the watch as they are all different, but similar in a way. This hold down bar across the battery may slide out of the way but most likely there is a small screw on 1 side of that bar that has to be either loosened or completely removed before you move that bar out of the way.
    Jun 22, 2010 | Timex Expedition 84601 Wristwatch
    I wish to replace the battery myself, how do I do this?
    Polar tells its customers to send watches to them for battery replacement. But the Polar Fitwatch is too old (may have been introduced in 1997?), and they no longer support it. So the only solution is to replace the battery some other way.
    For most people I'd say go to a store that sells watches, they'll replace the battery for a fee.
    For those who are handy, you can replace it yourself. I did mine yesterday.
    The battery is a common type - CR 2032.
    You'll need a small screwdriver, philips type, I think. Maybe around 00, or thereabouts. And you need tweezers, preferably with a rubberized grip.
    There are four screws holding the back plate. Remove three, and loosen the fourth. Slide the back plate aside.
    I unscrewed the screws, then used the tweezers to take them out. They're a bit small for your fingers to get a good grip on them.
    The battery is held by a plastic holder that's held by 4 screws. These are (to my eyes) slightly smaller than the ones holding the back plate, so please keep those separate - and keep track of all the screws.
    Remove the plastic holder, and make sure you keep track of the spring that's between the holder and the back plate. It'll likely fall out when you turn the holder over.
    The holder keeps the battery with a small prong, but it's easy to slide out the battery. Replace the battery, getting the orientation right, making sure you don't touch either side with your bare fingers. This part is easier than it sounds.
    Replace the holder, and of course you noted beforehand what the orientation was, so you get it in the same position.
    Use the tweezers to drop each screw into its hole, then screw it in.
    By this time, the watch will probably start beeping when you tighten one of the screws, because you depress one of the buttons on the front.
    Put the spring back in its hole, then slide the backplate back into place, and drop the screws in place with tweezers and tighten one by one.
    You should be able to find a manual (which doesn't cover battery replacement procedure) by searching for polar fitwatch manual.
    Apr 28, 2009 | Watches
    Movado Museum Esperanza 604122 Wrist Watch Logo
    79 people viewed this question
    Top Movado Watches Experts
    Are you a Movado Watch Expert? Answer questions, earn points and help others
