Question about LG WM-2277HW Front Load Washer
LAUNDRY SOAP CAN I USE DREFT LAUNDRY SOAP IN MY LG FRONT LOADER WASHER?
  • 489 Answers
Yes you can but remember to only use 2 tablespoons of detergent.  It may not say it in the owner's manual but it is what the factory is telling us to relay to the customers.
Posted on May 26, 2008
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
I wash massage sheets and the oil is not comming out of the sheets with the HE liquid laundry soap can I use a none he degreaser without hurting the machine
Don't use non he detergent in washer dispenser it did mess mine up. But u can try adding a cup of white vinegar into the washer itself when you load it to help cut the oil from the fabric it works when I was pool towels in the summer
Jan 18, 2012 | LG WM-2277HW Front Load Washer
Can we use powered Dreft Detergent to wash our baby clothes. Have been unable to find liquid detergent for baby clothes. Please respond promptly.
I would highly NOT recommend it. powder likes to clump inside the front loads. I would use a fragrence(SP) free soap if dreft is not available inliquid or h.e. as well be aware most baby detergents are not flame retardent. meaning in case of fire the soap residue left on the clothes naturally do not resist to flames as most detergents do.
Nov 03, 2010 | Frigidaire Affinity ATF7000E Front Load...
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
Front-load washer doesn't clean!
I don't know anyone who thinks the front loader is better except for stacking things on top of...
Certainly the performance of the modern water-saving front-loader is questionable when compared to earlier models - which is why I think a wash takes much longer these days with a modern machine, I think it has to in order to be effective. My friend's new front loader can take a couple of hours to complete a programme and it is only a washer and not a waser/drier.
The older washers used to take everything that could be pushed inside and the laundry would emerge smiling. These days overloading is a complete taboo and should be weighed to ensure nothing is strained.
Your washer might have a fault but in the final analysis you made a contract with a retailer to, in return for a consideration, supply you with a washer to clean your laundry. The supplied washer doesn't clean the laundry in spite of your best efforts and that means the retailer has broken the contract. It is up to him to sort matters out to your satisfaction.
Mar 25, 2017 | LG WM2016C
LAUNDRY DETERGENT
Greetings MOMMA2,
Typically it is recommended to use only HE (High Efficiency) in your front loading units. The difference between HE soaps and normal detergents is that they are low sudsing soaps. HE Machines need low sudsing detergents and if regular detergent is used, the excess suds could lead to washer problems. Unfortunately just using a smaller amount of regular detergent does not fix the issue. Only the use of HE detergent assures the proper performance of your unit.
Due to this, it is NOT recommended using Dreft in HE machines.
One recommendation out there is to look for 2x Ultra Tide HE Free, which is made without dyes or perfumes.
Thank you,
Dorothy
Go Ahead. Use Us.
May 24, 2008 | LG WM-2277HW Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
Lg tromm soap dispencer won't open
nothing to lock it fully closed......pull harder!
Jul 21, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM-2277HW Front Load Washer Logo
93 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
