Question about Hitachi 50SBX70B 50" Rear Projection Television
Hi, I have a 1997 hitachi ultravision. I use direct tv. I have lost the picture however, every minute I get a quick flash of the channel I'm watching. It continues to flash for 3-4 more times and then a minute or two the picture is lost. no problem with the sound. what do think? thank you
  • 15 Answers
SOURCE: How do we program channels without remote?
Greetings,
Take a deep breath, Hold it. Now relax and sit down and read the owners manual. I know it can seem like information overload but the only way to know what your doing is to follow the directions in the owners manual.
Hope this suggestion will help you out.
Posted on Jan 06, 2009
  • 72 Answers
SOURCE: hitachi ultravision 2005 turns on for about 5
could be shoted convergence ICs
Posted on Jun 07, 2009
  • 668 Answers
SOURCE: Hitachi Ultravision 46UX50B Flickering/Dead Display
It is possible that you have some loose connections, but I have seen the relays in the power supply get to be intermitent and will not stay closed. Tapping lightly on the relays will usually tell whether or not they are bad.
Posted on Jun 30, 2009
SOURCE: TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Posted on Nov 19, 2009
ladywinn
  • 5138 Answers
SOURCE: Hitachi Ultravision 50in. Does not turn on at all
replace Both of your STK ICs STK392-570
Call Mats 1-800-628-1118
Posted on Jan 03, 2010
Hi! my tv hitachi 50v500a ultravision had problem the screen of the tv have big red cloud
There is no solution - eventually the entire picture will turn blue. It's out of warranty and replacement of the light engine is way too expensive. Start shopping for another tv - I did
Dec 24, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Jan 03, 2010 | Hitachi 50UX57B 50" Rear Projection...
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
Aug 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravison 50 in HD TV w/o sound or video access
Good Day, smuffin;
You may have a bad LAMP (part #; UX21516), it's about time, check lights on front panel of TV.
To replace LAMP remove Front Panel outwards until the quick snap disengages. There is small cover on the left hand side, using a philips screw driver; remove. Two more screws secure lamp, use handle to remove. ALWAYS, unplug TV from A/C power source first. Good Luck, big IRISH.
Sep 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
No picture
Good Day, Young33dm;
If you have the BOX showing OSD, (On Screen Display), the BOX is bad. Get a new box or try resetting the BOX by unplugging it for 2 to 3 minutes, then plug back into A/C source.
Sep 01, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision
NEED TO CHECK the convergence ICs "stk _ _ _" , also check for some burnt spot (dry solder) around the power supply,
hope this helps AJ
May 12, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi Ultravision will not change channels
Tuner may be fubar is the only logical explanation. Use external one. Repair not cost effective
Aug 27, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
