Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer will not spin. motor runs. can move drum by hand. how do I remove the transmission if that is the problem
  • chewytwo Sep 29, 2010
    switch is fine
  • 51 Answers
Check the lid switch, it is located under the top base frame, look where lid male plunger goes into the top of machine.
Posted on Sep 29, 2010
  • Robert Johns
    Robert Johns Sep 29, 2010
    That machine has a washer drive belt check that and get back if it is in place and not broken or loose.
    the washer agitates, but has a loud "thump", but won't spin
Washer making a humming sound want do anything else
what's the brand name and model number?could be the motor you hear humming,something could be stuck in the drain pump depending on the model you have or there could be a piece of clothing stuck between the tubs,a bad start capacitor but if the motor is humming either something is jammed and won't let it move or the motor could be bad but you have to send more info.
Dec 22, 2017 | Washing Machines
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Motor smell hot drum will not spin or pump out water Maytag atlantis
Im not an expert, but.Ok, but it wash? The only problem is at spin? if not wash at all:
Disconnect from the outlet, remove the belt, and by hand turn the pump and drum. Its suppose to move with low resistance in both directions, will not spin freely, but turn easy by hand. Do the same with motor. IF the drum and pump moves in both directions, I suspect about the motor.
If the only problem is at spin:
Do the same, but place special attention at the drum when you turn in reverse. Look if you see the brake Disk turn.
Nov 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
My Kenmore Elite HE 3 model #110 4822 201 will not spin. It runs through an entire cycle and fills and drains. The drum will turn a few turns clockwise when spun by hand but then will not move further...
Hello there:
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool and Kenmore have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Jan 15, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
On spin cycle, the drum will not spin
You have a bad coupling. It is between the transmission and the motor.
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Front Loader spinning failure
check you can turn drum by hand if rotates freely then youre motor brushes will have worn out the motor needs to be removed to fit replacements but they are cheap to replace.
Aug 10, 2008 | Neff W5340X0 Washer
Not spinning
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jun 14, 2008 | Washing Machines
Maytag Washer PAV2300AWW
Your Thrust bearing on the bottom of the transmission is not releaseing the break. try turning the pulley with the belt off in the opposite direction this should free up your break. If it doesn't replace your brake ststor and rotor as well as your thrust bearing. This should solve your problem. Roger
Sep 26, 2007 | Maytag PAV2300 Top Load Washer
Kenmore washer
It could possibly be a motor coupler that has broke. Its a small rubber disk mounted on plastic drive joints. Its located between the motor and the transmission. This coupler is made to rip or break in case of something more serious, sort of like protection for the motor or transmission. Jim
Sep 06, 2007 | Washing Machines
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
111 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
