Question about Alcatel Cell Phones
LED calibrations are off. Can't access the menu for an Alcatel touchscreen phone.
  • 3 Answers
I dont know if this will work for you, I had the same problem on the 708 model, in the end I figured out that what I thought was the aerial can be pulled out & used as a pen ,or the 'stylus'.
Posted on Feb 11, 2011
Touchscreen not responding on Alcatel 4015t
seems like the phone is locked in restricted sight mode.
Feb 26, 2015 | Alcatel Cell Phones
The touchscreen on my Samsung Brightside is too sensitive. Is there any way to reduce its sensivity?
go to the settings on the phone and look for the accessibility settings. under the accessibility settings there should be a screen calibration option. if present select it and follow the directions. generally the touchscreen sensitivity can be calibrated to help deal with most sensitivity problems, but the problem can also be inherent with the type of screen used in the phone and the hardware related to it so beware that this might something that cannot be truly "fixed".
Oct 17, 2013 | Cell Phones
Touch calibration Alcatel OT-880A
hi there, i just want to know if the problem is solved by now, cause i need the solution too cause i have the same problem with my alcatel ot 880
Dec 22, 2011 | Cell Phones
My touchscreen is not work
If your touch screen is not working, theres just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jun 18, 2011 | LG KU990 Viewty
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
My touchscreen calibration is out of sync and it will not allow me to get to the menu to fix it
Hi have you tried taking the battery out wait a few minutes and put it back in and start the phone it should fetch the calibration screen up for you to calibrate if your digitizer is still working.
best of luck.
Dec 20, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
I have problem with touch screen n98 plus dualsim i cant make touchscreen calibration
A REGISTRY EDITOR will allow you to input the touchscreen configuration numbers manually. Of course, none of these will be much good if you dont have 'Windows" phone or cant access your Registry!!
If all this fails, ASK 'XDA DEVELOPERS', or 'MoDaCo'.
Aug 25, 2010 | Cell Phones
HOW CAN DO PHONE CALIBRATION?
Over the time, the touchscreen might have to recalibrate for better touch precision. If you press 1 but it activates 2 in the To calibrate Nokia 5800 touchscreen: Click the menu key > Settings > Phone > Touch Input > Touch screen calibration. There you are prompted to tap centre of target with stylus, where the 4 circles (target) at the corner animates one by one to guide user complete the touch screen calibration process.
May 05, 2010 | Nokia 5800 XpressMusic Smartphone
Cell Phones Logo
687 people viewed this question
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
