Question about Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic F09 error code.
My Panasonic dvd/vcr recorder has the error message F09 on the front display. In the past, this occured, but after I unplugged it and reset it went away. This time it will not go away. I opened it up to see if a loose capacitor was the problem like I read on this site, but nothing looks out of place. I contacted panasonic support, but they cannot repair for free because I no longer have the receipt. please help!!1
  • 1 more comment
  • davidcook08 Aug 15, 2008
    panasonic dmr-es30v fault code f09
  • whytewabbit Dec 09, 2008
    F09 error on Panasonic display can any one fix it ? andy thanks
  • Anonymous Apr 07, 2009
    My Panasonic dvd/vcr recorder has the error message F09 on the frontdisplay. In the past, this occured, but after I unplugged it and resetit went away. This time it will not go away. I opened it up to see if aloose capacitor was the problem like I read on this site, but nothinglooks out of place. I contacted panasonic support, but they cannotrepair for free because I no longer have the receipt. please help!!1
SOURCE: F09 error message on Panasonic
2 x 1000mF capacitors in the power supply trying to burst.
Posted on Dec 04, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
TEKUSER
  • 86 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
SOURCE: panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Posted on Jul 01, 2009
SOURCE: Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Posted on Jul 25, 2009
DVD player. NV-VP32 shows F09 error. No buttons are working. Have unplugged and waited 5 mins then re-plugged and it still shows F09 error.
Hello
F09 indicates electrical overload. If you've got some basic soldering skills, you might open the case and check for a ruptured capacitor and try replacing it. Repair costs range about $50 a hour, plus parts, but parts usually only add another $10 or less. Check with a repair shop and see what the usual cost is, on average.
Apr 16, 2011 | Panasonic DMR-ES30VS DVD Recorder/VCR
Mt dvd/vcr combi displays a message U61 and the
Nothing is happening because the firmware can't recover/repair the error. Yes, you must take your unit to a dealer, this is a hardware fault and the faulty part must be replaced.
Jul 28, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-ez48v error f09 what is it?
If I have got the right machine than F09 is an electrical fault. If It is a K Deck model (you need to check) then it means: No serial clock linking IC2004, IC7005 and IC7701.
Nov 14, 2009 | Panasonic Televison & Video
U61 error code on Panasonic DMR-ES35V DVD recorder/VCR
Replace it, it is not cost wise to have it repaired.
Jan 01, 2018 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
PANASONIC DMR-ES30V KEEPS SWITCHING OFF
I had this code (f09) on my Panasonic DVD VHS recorder. After seeing that it meant overload I took the cover off to look for burnt out components. I found that an electrolytic capacitor had bulged (look up capacitor plague on wikipedia). I replaced the capacitor with one of a similar value from an old power supply and it worked fine.
Feb 16, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
VCR DVD Combi DMR-ES3OV
May 08, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR Logo
1,518 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
