Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Makes screaming as washer is being filled. - Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Knowing what you`ve provided "Makes screaming as washer is being filled"...
the issue is likely with the inlet/water valve being noisy. To remedy this, first check your water pressure is adequate or the supply line valve is completely "open".
If you can rule out the issue of water supply pressure being the culprit, you will need to replace the valve, not surprising for Bosch unfortunately.
i.e.
As long as your model number is indeed SHU66 series, this info below will be accurate.
I say not surprising because this part has been an issue for the B/S/H/ built machines in the past and as a result the original part number 189553 now substitutes to 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
Replacing it is pretty straight forward. Here`s how...
1) undo the water line.
2) the two #20 torx screws fastening it iMakes screaming as washer is being filled. - 156e176.jpg>
3) the feed tube to the machine aMakes screaming as washer is being filled. - 5937279.jpgof the valve and swap it with the new one.
Makes screaming as washer is being filled. - dd52c6a.jpgsrc="http://i.fixya.net/uploads/images/5937279.jpg" alt="5937279.jpg" class="h_mi" />
and
Once the new one is in you should be good to go.
Let me know if you need any further assistance, otherwise good luck.
Thanks for visiting FixYa.
Regards,
Macmarkus :)
Posted on Sep 29, 2010
  • 51 Answers
Inlet water value is failing, try on different setting(hot, cold,warm). If the noise stops replace water value.
Gentle annie
The fill switch may have failed or the tube to it broke. Anyway, the machine probably is too full of water for it to start to spin out, so it slips on the belt and that makes noise.
The machine is going to be very heavy if it is overfull, but try to let some water out. Maybe you can just lower the drain hose way down into a bucket and get some water out of it. Once it's low enough, it may be able to pump out the rest. Then you can find out about the fill switch.
If it's not overfull, then some hose came loose or broke.
Nov 25, 2013 | Washing Machines
Makes screaming noise while washing. MAV7200. Belt or Bearing? Fixable by DIY?
MY MAYTAG WASHER IS MAKING A NOSIE WHILE WASHING A GRINDING NOISE DON'T KNOW IF IT THE BELT OR BEARING? WHAT DO I NEED TO DO?
Jul 20, 2010 | Maytag MAV7200 Top Load Washer
Washer makes awful screaming sound in spin cycle. Is this transmission issue? Repairman seems to think so and fix is so expensive it's almost not worth it, which means buying a new machine.
if its a front load then its the drum bearings that are out of it and you need a new lip seal and bearings,the parts are not expensive but it takes time to dismantle the machine to install these parts
May 24, 2010 | Kenmore 98702 Stacked Washer/Dryer
F&P Intuitive washer IW812 very noisy water
Traced the problem back to the tap. Seems the washer in the tap was faulty and producing a screaming graunching noise. Replaced the washer and all OK
GK
Nov 12, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Our IWL12 is making a screaming sound when filling
May just be the sound of the water running thru valve. try adjusting the tap and see if it changes the noise
Jun 29, 2009 | Fisher and Paykel IWL12 Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Maytag top load washer
Belt could be worn and screaming
Sep 01, 2008 | Washing Machines
My dryer
I have a WTL5400 screaming at me, so my Husband has taken the side and back panels off to investigate,and the noise was made by the air outlet plastic fan which spins when the tumble dryer is turning, this plastic fan thing was wibbly wobbly and the nut wouldn't tighten up. He has put in a couple of different size washers and tighten up the nut and hey presto no noise.
Oct 16, 2007 | Dryers
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
223 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
