Question about Jandy PHP High Head Pump 2 HP Up rated
I've got a Jandy pump. Sometimes, when the pump is off, I see a few small air bubbles at the top of the pump lid. Is this normal. No air comes out of the returns.
    Novelist:
  • 116 Answers
Well, normal is a relative term.... But not uncommon at all. In theory there should be no air getting into the system. In reality air sneaks in through a number of places, such as loose connections and fittings, old o-rings, and also when I cleaner comes out of the water, or water gets low and air sucks into skimmer, or if skimmer door sticks, etc., etc. As long as the pump is not running dry a little air hurt anything. If however you have a tab chlorinator, and air is trapped here this can be bad as chlorine gas is very corrosive. A lot of air trapped in the filter can be bad as this can create hydraulic pressure and cause undue stress on the filter. If the filter is working properly air should be forced through the filter and back into the pool. Open the air bleeder on the top of the filter occasionally after the pool has been running awhile and make sure there is not a lot of air trapped inside. Hope this answers your question. let me know if you need further assistance by commenting on the post, and don't hesitate to m give a positive rating if you found this helpful. Thanks, and Good Luck!
Posted on Sep 29, 2010
Testimonial: "Thanks for your feedback. Its a new saltwater pool. Can tightining the pump lid while the pump is on be harmful...should you not do that? thanks."
  • 2 more comments
  • Imthedude Sep 29, 2010
    macdirk- do you mean that some air can be trapped by the polaris (pool cleaner) coming out of the water periodically?
  • Derek
    Derek Sep 29, 2010
    Um, Yea, that's not advisable. With some pumps it's not a big deal, but the bottom line is when the system is running the lid is being sucked down pretty tight, and so it's hard to tighten. It's always best to turn off then adjust. If in doubt replace the o-ring, and only use enough lube to make the o-ring moist, not all gooped up. Believe it or not too much lube actually can allow air to get sucked in easier. Some pump/lid/o-ring combinations will seal well even when o-ring is old and worn out, others will leak even if the o-ring is just a little worn. if you over tighten the lid, eventually it can crack or break, and a lid cost a lot more than an o-ring. If you damage the pump itself, well you know that aint cheap. Lid should only be hand tight, not wrench tight. if the lid pump and o-ring are all clean, new and lubed properly just snug should seal nicely. If it's currently all gooped up, and dirty, etc, (or if it gets this way in future) clean it up really well then reapply lube as stated above. "Simply Green" or other similar household degreasers, (or even paint thinner), and a soft to med bristle brush works pretty well to clean the old lube all up.
  • Derek
    Derek Sep 29, 2010
    well if it's a suction cleaner, and the cleaner comes up out of the water, then yea some air can get in the system. But, as i stated earlier this isn't a big deal. If the filter is working properly (the internal air bleeder screen not all plugged up) then the air should bleed out on it's own. I only mentioned this to explain a common way that air can get into the system. If there is a little air in the top of the pump pot, that's no big deal. Depending on the power and flow of your pump sometimes this will churn and get sucked right through the system in seconds, with some setups, it will always just always seem to have a little air trapped in the lid. not necessarily a big deal, as long as things sound and work fine. if you have constant bubbles flowing back into pool, then there is a definite leak somewhere. For example, lets say your system works perfect and there are no air bubbles coming into the pool, or trapped in the pump pot. If the cleaner climbs the wall, comes out and sucks in some air, this will obviously run through the system and blow back into the pool. this could happen in seconds (more likely a minute or two), or it could sort of get trapped in the pump pot, and filter, and maybe slowly blow tiny bubbles into the pool over the next 10 or 20 minutes.
  • Imthedude Oct 16, 2010
    Thanks again for taking the time to help me with my questions.
How do I fix a toilet that bubbles (small air bubbles from below) and flushes slow, and not completely very often?
Remove the toilet & have a plumbing company power snake
as much of the entire homes waste drain as possible
Maybe clogged inside the home on most runs & also out to
the street,have them do as much as they can, out to the street
Remove all toilets, so they can do good job & you can check &
clean them from under it
Have them run a camera down ALL drains & to the street
Jul 19, 2014 | Briggs Abingdon Ada Toilet Express
Air in whisperflo window, bubbles from pool jets
This is a air leak on your suction side between the skimmer and the pump. You will not see water in the yard on the suction side usually, only the return. It is usually just the fittings around your pump or the seal around the pump lid, check those first and make sure you do not have a loose clamp or a damaged or dry seal. If that is not it then call in your local service guy to determine where the leak is. They will most likely pressurize your suction line to find the leak. Hope that helps.
Time to Open the Swimming Pool
May 03, 2014 | Pentair 1.0 Hp Whisperflo Pump
Pump has big air bubbles and vacuum stopped working
check intake union to see if loose or leak if all ok pump seal could be leaking on intake side or could have debris in impeller clean out with a piece of wire
Jun 29, 2012 | Pentair 1.0 Hp Whisperflo Pump
Air bubbles in radiator
when the motor is off open the lid and slowly squeeze the top radiator hose and it will bubble the antifreeze at the radiator some may spill out but after u squeeze it simultaneously it shouldnt bubble anymore and then just refill what spilt out
Feb 20, 2012 | Holden Rodeo Cars & Trucks
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
When trying to circulate i have alot of bubbles and it won't pick up the water to circulate it
THERE IS A SUCTION LEAK COULD BE .. PUMP LID, JANDY VALVE OR CRACK AND OR LEAKING PVC .. YOU CAN USE ELECTRICAL TAPE TO DO EACH JOINT ON THE PVC.. START FROM THE PUMP AND WORK BACK AS FAR AS YOU CAN ON THE SUCTION LINE, WATCH THE BASKET FOR THE BUBBLES TO STOP, WHEN THEY DO THAT IS THE JOINT THAT NEED TO BE REPAIRED..ALWAYS PRIME THE PUMP WITH WATER AFTER A PUMP REPAIR.. BEST OF LUCK .. JAY THE POOL PUMP REPAIR GUY LONGWOOD FLORIDA
Jul 26, 2011 | Pool & Spa
Have to prime pool pump every time to get it working dont seem to be any leaks
there is a suction leak, cold be lid o-ring, crack in lid or basket, the fittings.. use electrical tape and do each fitting one at a time, watch for the bubbles to stop in the hair basket jandy valves are sucking air, get rebuild kits for your valves on the suction side.. but the first thig i check is the impeller and shaft seal.. prime the pump after any repair !!! .. here is how to remove your pump ..
Feb 12, 2011 | Pool & Spa
How can i determine if the water pump is working? i replaced the radiator and the thermostat. The car continues to over heat. any ideas? Also how can i bleed the air out of the system? could the water...
If you squeeze the upper radiator hose and it feels like the coolant is running thru it, your pump is working. The system should bleed itself within a few minutes if you keep the radiator and reservoir full. If it continues to bubble, you have a blown head gasket. :-(
Let us know if you need more help.
Sep 12, 2010 | Dodge Intrepid Cars & Trucks
Jandy PHP High Head Pump 2 HP Up rated Logo
239 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
