Question about Maytag Dryers
Maytag dryer goes on but clothes are not turning
  • 20 Answers
Can you turn the drum by hand? If not there is something Jammed in the blower housing.Do you hear the motor running? Is there Air blowing out the back? If there is air blowing out & you hear the motor it will be the belt. If you do not hear the motor & no air is blowing out then hold the door switch in & turn it by hand as you push the start switch it might start working, If it does it wont last long. If it does not start it is the motor.
Posted on Sep 29, 2010
  • 51 Answers
Replace drive belt.
Maytag Dependable Care Plus/Heavy Duty Dryer Model # LDG9304AAM Dryer is turning, there is heat but clothes are not drying
HI- Usually when the clothes take a long time to dry it is an issue with the vent. Look in the back of the dryer and make sure the vent is not crushed, crimped or blocked. As well, go outside when the unit is running and feel how much air is coming out of the exit vent. It should be blowing pretty good. If not replace and clean the vent, if the vent goes through the wall and makes a bunch of turn over a long distance you will need to have a vent cleaning service out to brush and vacuum the vent. You can test this by detaching the vent where it goes into the wall and putting pantyhose over the end and see if it dries better. You could also have a thermostat issue but I look at the venting first. Hope this helps.
Sep 24, 2010 | Maytag Dryers
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
My Maytag Quite Plus clothes dryer gets warm but not as hot as it use to. It seems to take a very long time to dry clothes. Vent is clear. The moisture gage seems to flicker lately.
most dryers have two heating elemts and when one goes out this increases the drying time and could cause a elec. short and trip a braker can be replaced.. There is also a saftey switch that goes bad and will not let the heating elemt work properly ?
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The Timer Knob on my Maytag Dryer does not move. The drying just goes on and on unless I notice and stop the dryer.
While the dryer is turning slowly advance the timer knob to the end of the cycle. The dryer should stop. It sounds as if the timer motor has died or is not being powered for some reason and is not advancing the timer.
Nov 12, 2009 | Maytag Clothes Dryer Almond Timer Knob...
Magtag Dryer MDE2400 Dryer won't turn off
On our Maytag dryer, the looping marquee lights mean that the dryer is in "wrinkle" mode. This means that the wrinkle mode has been selected. In this mode, the dryer continues to rotate on and off after the heat cycle has ended. It does this to keep the clothes from wrinkling -- and it displays the looping lights.
Jul 24, 2009 | Maytag MDE2400A Electric Dryer
Maytag Neptune clothes dryer Model# MDE4000AYW Noisey squeeking sound. However, after a few minutes when it heats up, the sound goes away.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
trxcvhj
Jul 05, 2009 | Maytag Neptune MDE6700A Electric Dryer
Dryer is not functioning (It doesn´t get clothes dry)
Usually the ignightor goes out in them. If you have a meter or way of measuring it, you can take off the front panel and it'll be on your bottom left side. You can disconnect it and you should see a short. here is a link to look at and it might help in the dissasembly prosess. By the way, when you 1st turn it on, you should hear a click within seconds down my that also. If it clicks it's very much so the ignightor. Pretty easy and cheap to do. Good luck
http://www.searspartsdirect.com/partsdirect/getModel!retrieveModelDetails.pd?modelNumber=MDG7400AWQ&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY
Mar 14, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer goes with 3-4 cycles to dry load of clothes
unplug the dryer.
Open the top lid.
Remove the front panel.
Inspect the blower wheel attached to the motor.
If it moves on the motor shaft replace it.
If iy does not move on the motor shaft, clean the lint out of the exhaust from the blower wheel to the rear of the dryer.
Mar 12, 2009 | Maytag Dryers
Dryer stopped working during cycle
is dryer drum turning u might be amotor are some other problem you may want to call a service tech to fix your dryer ok
Oct 21, 2017 | Maytag Performa PAV2200
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
282 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
