ynot you need to give some official repairer to fix it, because it is a water damage maybe the device can anytime make a short cicrcuit and damage the device permanently so disconnect the battery and take to some official repairer, for the freezing there is 2 possibility hardware issue (LCD running screen freeze due to water damage) or software issue (software problem), for hardware issue you need to show repairer for the software try to hard reset device but this procedure will delete all data so first make back up, for the hard reset try this process :
1. switch off device
2. press and hold volume up+lock button + green call button +power on button, all together;
3. then device ask you "are you sure want a format"
4. select format, after finishing all, use your device for check persist problem or not, probably not because this is a minor software problem. Best of Luck, if my suggestion was helpful ,please rate it.
Source :
http://www.hard-reset.com/samsung-i8000-omnia-ii-hard-reset.html
