Teledyne laars pool heater wont kick on
Pilot light is lit, vacuumed out spider webs, heater wont kick on...
  • 9 more comments
  • Anonymous May 30, 2008
    laars heater piliot on main vale doesnt come on
  • Schrades Jun 01, 2008
    Pilot is lit , pump running but burner won't light up?
  • Anonymous Jun 17, 2008
    Laars Lite 2 Gas valve on, adequate gas flow, pilot on, backwashed pool, psi less than 10 psi, pool person who opened pool claims he had it lighted??, everything clean, lines all open, Whats up?
  • bambireno Jun 29, 2008
    Hello \I too have the same problem, Where exactly should one vacum
    Thanks
  • Anonymous Jul 24, 2008
    heater will not start
  • avanmaren Aug 05, 2008
    heater pilot light is on but the heater won't turn on, did backwash, so pressure is fine.
  • Z54Burma Aug 05, 2008
    Where is the safety valve relative to the pilot on a Teledyne Laars EG-175 heater or similar?
    I'd like to try to clean it as suggested.
    Thanks.
  • Anonymous Aug 23, 2008
    pilot on burners won't kick in. Thermo switch seems to not function all the time. Is there a way to light the burners by passing the switch?
  • scottmurphy Aug 25, 2008
    have the same problem with a laars teledyne 400,000 btu. Yes it's older than dirt but the insides are pretty clean. It works great most of the time but will not kick off intermittantly. Pressure is fine etc. I can see the pilot is blue but the gut's are pretty old. It seems to help when i clean all the connections but that may just be chance. where is the valve to clean? Thanks
  • slade8 Mar 20, 2009
    teledyne laars model ESC400H, hear clicking but will not ignite. Gas is on but I also never smell gas no matter how long I leave the switch to "on". Has an electric igniter for the pilot. Water pressure is normal.
  • pdmac67 May 21, 2009
    I have a lasrs lite 2 175000 btu,its propane,my pilot is on,propane wont kick in,cant smell the gas,is it the pressure switch?how do i bypass it just to make sure before i order one,as they wont take it back?
  • 868 Answers
The safety valve isn't opening .It's very possible that a spider is trapping the opening of the orifice.
Posted on May 26, 2008
  • Bob Pell Sep 24, 2010
    Ok I have the schematic and manual for Teladyne lars EG 175 unit and there is no such thing as safety valve anywhere to be found. Two things to be checked- 1. swithces/sensors (pray to god it them) 2. gas valve (pray to god its not this as it will cost you $270 big ones)
    place a jumper between 2 closets wires to you on the control valve (there are 4) dont have the colors of wires as I am work now. If the heater comes on then the you have isolated the problem to protective controls or thermostat. If heater does not come on then its the gas valve/wire harness grounded/pilot light.
    If the heater worked fine before and now all of a sudden its not - you can eliminate the pilot light as the likelihood of it being out of position is far fetched. To test for grounded wire remove the first two wires facing you from the gas valve(same one from above) place a jumper across terminals and if the heater lights up something is grounded and you need to check all the wires. if this doesnt solve the problem the only thing left is the gas valve being struck closed and time to do some R/R. Hope this helps
Laars pool heater's burner wont stay lit
Check the burner, the holes may be plugged, especially at the beginning of the season. Same happens to the pilot light tube. Spiders love to make nests inside those small holes clogging everything up.
Aug 13, 2014 | Teledyne Laars Pool & Spa
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater was working fine but it stopped. I'm wondering what the problem might be. I've backwashed the filter, checked for dirt and spider webs inside the unit, turned off and on the knob....but no luck
If your Laars will not stay lit then the pilot generator is faulty. That is the small brass and copper piped connection near the pilot flame. It must produce 250minivolts in order to open the main gas valve and keep the gas running into the pilot burner..
please visit http://www.laarsman.co.uk for more help
Miles X
Jun 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
We have a teledyne gas furnace whose pilot won't stay lit. Any ideas?
Is this a standing pilot,or pilot always on.
If so a bad thermocouple will cause pilot to go out.
Thermocouple is a small copper tube running from the pilot light area to the gas valve. easy to replace.
Jan 14, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Jun 15, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
1,463 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
