Question about Whirlpool Duet GHW9150P Front Load Washer
F02 code is on the drain pump sounds rough. - Whirlpool Duet GHW9150P Front Load Washer
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
The "F02" on your model of washer indicates the machine has detected a fault or obstruction in the drain process.
The same error as the "F21" on the later model Kenmore/Whirlpool units.
Chances are the pump itself is being obstructed by debris or some other foreign object as opposed to being faulty, although the faulty pump can`t be ruled out...yet.
Here`s how to check it and clean it...
Though it being full of water may make it messy. A wet-dry shop vac is handy in this situation.
If it is in a position that allows you too lean it back against something strong or a second set of hands it will help if tilted back almost all the way.
Careful not to hurt the machine or yourself, and undo the fill hoses and drain hose.
**Turn off the breaker at the service panel or unplug the washer from the wall socket...safety first**
1) locate the screws in front at the very bottom of the panel below the door and pull the panel down and forward until it is off. They will be either 1/4" hex head or #20 torx head screws.
2) You will immediately see the drain pump in front of you with a large removable filter. ( **see image below...this is were a wet-dry shop vac and towels come in handy, also the use of the removed panel as a catch pan is beneficial...but you may still get wet )
3) Turn it counter-clockwise should allow you to remove it and inspect it and clean it out. Make a good thorough inspection inside the pump as well not just the removable filter.
4) Re-insert the filter and before placing the panel back run a test rinse/drain cycle to inspect for leaks and to verify the unit drains and spins now.
( If the problem still exist`s the "F02" will re-appear. If so you`ll need to check the hose/rubber bellows from pump to tub...back-flow ball...for other obstructions ).
5) If all appears OK after your efforts, well your efforts paid off...pat yourself on the back. You just saved yourself potentially a couple hundred bucks !
Now You should be good to go. Re-attach the lower panel and you`re back in business.
**NOTE: if this still fails to remedy the F02 or if it returns immediately during the next drain you may require a pump unfortunately...part # 280187 available at "searspartsdirect.com" "repairclinic.com" etc.
**This however can also be caused by the back-flow ball inside the bellows which connects the tub to the pump. There is a large clamp which secures it to the tub, but if you remove it to clean out all the dirt built up inside, make sure you get it good and secure when putting it back.**
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
Posted on Sep 29, 2010
I have an f2 error code on my kenmore oasis washing machine model number 110.2803
HI,
You have a extended drain problem. Most likely you drain pump is clogged and causing your unit to fault out after 8 minutes of attempting to drain.
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Read more:http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1WKO5b8KR
I hope this helps.
Aug 28, 2011 | Washing Machines
Tip
F02 Code
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
If the pump motor or impeller becomes damaged and does not pump at the correct volume, the error code will not clear. If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Apr 05, 2010 | Washing Machines
Tip
F02 Error Code
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
on Dec 09, 2009 | Washing Machines
Keep getting f02 code and check all drain hoses and the pump for debris and the filter and still keeps getting the code and the pumps sounds like it is runnning or just humming
unplug the machine f02 is something is caught in your hose or your pump or your drain line F02" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system somewhere. In most cases this means there is a clog in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced once again please message me back if you have any further questions and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | Kenmore Elite 45986 Front Load Washer
F02 error
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
Mar 25, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Will not drain. Getting error code F02
yes exactly.you are right.its the pump problem. F/02 error code:-- Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
try this :-- Press PAUSE/CANCEL twice to clear the display.
:Check the drain hose and make sure it is not plugged or kinked.
: Check the electrical connections at the pump and make sure the pump is running.
: Check the drain pump filter for foreign objects.
: If the above does not correct the problem, replace the pump.
you can get required parts from www.repairclinic.com
Nov 27, 2009 | Kenmore Washing Machines
It quits on the drain cycle and a error code f02 appears
Error F02 code means Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed. Solutions: Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 is flashing, still in wash cycle
Potential Causes
Apr 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
76 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
