Your "Favorites" were on your old harddrive and unless you backed them up prior to the crash, you won't be able to retrieve them.
Rating Locked! (?) Ecug97 has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on are favorites saved on the hardrive-:
Solution #2
posted on Jun 16, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
Hi ,
All PCs/servers must be backed up.
Without a backup , you must always start from scratch to re-install everything.
If you cannot afford backup , hard disk recovery charges are even higher (more expensive).
It is still cheaper to backup and be ready for emergencies.
If you do not backup regularly , you run this risk.
Even then , you must also regularly test recovery to ensure backup is sound.
Good luck,
David
Was this solution helpful? Show your Appreciation by rating it:
