Question about Targus (AMP0205USZ) Remote Control
I have a Targus remote Model PAUM30U--I had to change batteries and cannot get it to resync to the receiver in the computer to work again. I have lost the instructions that tell me how as I"ve only had to do it one other time. Please resend the instructions--thank you!
Johnboy36
  • 77 Answers
SOURCE: HOW TO SET UP AND USE TARGUS WIRELESS COMPUTER MOUSE
I assume this is a wireless mouse, Is there a similar button on the reciever? press this at the same time as pressing the one on your mouse
Posted on Mar 06, 2008
yooperbud
  • 8637 Answers
SOURCE: targus mouse remote
If the Red Light is on the batteries should be good enough to function. Try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
Joed911
  • 4338 Answers
SOURCE: change batteries in a targus portable mouse
I found the user guide in French. It says to slide back the cover behind the Logo on top.
also found it in English:
Installing the Batteries
Optical Mouse
1 Remove the battery cover from the top of the mouse by
pressing the top center (over the Targus logo) and
sliding it back.
2 Insert the supplied batteries , making sure that the
positive (+) and negative (-) ends of each battery match
the polarity indicators inside the battery housing.
WARNINGS: When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never
combine an alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device.
3 Slide the battery cover back in to position until it “clicks”
firmly into place.
4 Turn on the mouse by sliding the on/off switch on the
bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse,
glows red.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jun 07, 2009
  • 62 Answers
SOURCE: Making receiver and mouse talk
Check the Targus Website, They might have a manual you can download or contact them by sending them an e-mail or an old fashion letter and they might send you another one.
Posted on Oct 17, 2009
SOURCE: Hi, I have targus usb to 232 serialcable , model
To use a pao88 on Win7 64bit you will need to have Win7 Ultimate, Professional or Enterprise edition AND your computers processor must support hardware virtualisation.
Dowload and install the latest version of XP Mode.
Install the cable in XP mode.
Turn on USB compatibility in XP mode.
Cable will now be accessable in Win7 64bit
I connected and ran a successfull diagnostic test on an old serial modem without issue.
Posted on Mar 24, 2011
Remote key does not operate doors (batteries are new)
If you simply replaced the battery in the key, it fell out of synch with the vehicle, there is a procedure in your owners manual to resynch the key to the system. If you follow the procedure, and the key does not work, the system may have become disabled, and you need to go through the provedure again to enable it and synch the key.
If that still does not get it synched, you will likely need to take it to Benz dealership to have them synchronize it. Should run around 50 bucks.
Oct 28, 2012 | 1996 Mercedes-Benz C-Class
I have model CE 0560. New batteries are in. Pressed the dricer button which lights up. The redlight on the bottom of the mouse is on and flashing. The controls on the mouse do not respond.
You will need to follow the manufacturers instructions on setting up the mouse. Here is a copy of the instructions for download (Below is a viewable copy). Based on what you indicate, it is possible that the drivers are not loaded for the usb reciever or that one of the installation steps was not done correctly or completely. Please review the instructions and start from the first step.
Here are the instructions:
Targus Wireless RF Mouse USER’S GUIDE Making Your Mobile Life Easier.® Visit our Web site at: www.targus.com Features and specifications are subject to change without notice. © 2004 Targus Group International and Targus, Inc.. 400-0111-001B
System Requirements To use the RF mouse, your computer must meet the following hardware requirements and run one of the operating systems listed below. Hardware • PC with a Pentium® processor or equivalent • USB interface • Mouse • Receiver • 2 AAA batteries • Three inch USB extension cable • Carrying pouch Targus Wireless RF Mouse Operating System • Windows® 98/Me/2000/XP NOTE: The third button and the scrolling wheel only work with the operating systems listed above. If you use the RF mouse with a different operating system, it will lose its enhanced features and function as a standard, twobutton mouse.
Connecting the Mouse Receiver To connect the mouse receiver: 1 Plug the USB receiver into an available USB port on your computer. 2 Your computer’s operating system identifies the receiver and begins installing the default driver. Follow any on-screen procedures to complete the default driver installation. Using the RF Mouse Installing the Batteries 1 If the mouse is on, slide the on/off switch on the bottom of the mouse to the “off” position. 2 Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off. NOTE: The battery cover is also the top cover of the mouse.
Targus Wireless RF Mouse 3 Insert the supplied batteries, making sure that the positive (+) and negative (-) ends of each battery match the polarity indicators inside the battery housing. WARNINGS: When replacing the batteries, you may use alkaline or other heavy-duty NiMH batteries. Never use an alkaline with a NiMH battery in a device. Avoid mixing new and used batteries in a device. 4 Slide the battery cover back into position until it “clicks” firmly into place. 5 Turn on the mouse be sliding the on/off switch on the bottom of the mouse to the “on” position. The optical sensor, located on the bottom of the mouse, glows red. Establishing a Communications Link The RF mouse has 256 identification codes that allow the mouse and its receiver to operate without interference from other radio frequency devices. After your computer detects the USB receiver and the driver software is installed, you must establish a communications link between the mouse and its receiver BEFORE you can use the mouse. To establish this link, you need to set the identification code so that the mouse works properly. To do this, follow the instructions below: Make sure that your computer is turned on and has detected the USB receiver before you establish a communications link. 1 Press and release the link button on the receiver.
Targus Wireless RF Mouse Receiver The USB connector rotates 90 degrees to facilitate easy connection to your computer. The receiver’s status light blinks when the receiver is activated. 2 Press and release the reset button, located on the bottom of the mouse. You are now ready to use the RF mouse. Mouse Power Management To power the mouse on and off, slide the on/off switch at the bottom of the mouse to the desired position. efafd91.jpg
Mouse When power is on, the mouse goes into "sleep mode" after 8 minutes of no use. To activate the mouse, touch the sensor strips on the side with your hand. To save battery power, turn off the mouse while traveling or when you’re not using it. CAUTION: Turning off the mouse will require you to synchronize again the next time you turn it back on. 90° rotation Status light Link button Sensor strips Low battery indicator
Targus Wireless RF Mouse Operating Hints For optimal performance and RF reception: • Place the receiver at least 8 inches (20 cm) away from all electrical devices, such as your monitor, speakers or external storage devices. If necessary, use a three-inch extension cable to keep the receiver away from the computer. Plug the receiver into the extension cable, and the extension cable to the computer. • Avoid using the RF mouse on a metal surface. Metals, such as iron, aluminum or copper, shield the radio frequency transmission and may slow down the mouse’s response time or cause the mouse to fail temporarily. • The RF mouse will enter a suspend mode at the same time your computer does. To activate the mouse, touch the sensor strips on the side of the mouse. • If your computer has a metal case that contains aluminum or magnesium, use the RF mouse to the side. The display panel may interfere with the radio frequency signal if you use the mouse directly in front of the computer. • Never use the RF mouse on a glass or mirrored surface as these surfaces will cause the mouse to fail temporarily. • To maximize battery life, use the RF mouse on a white, or light colored surface. Dark surfaces cause the mouse’s light emitter diode (LED) light to glow brighter, which causes the battery to discharge more rapidly.
Targus Wireless RF Mouse Sleep Mode • The mouse’s sleep mode feature activates after 8 minutes of non-operation. • To wake the mouse from sleep mode, touch the sensor strips on the side of the mouse. • When the battery charge is running low, the battery indicator light at the end of the mouse glows blue.
Targus Wireless RF Mouse Troubleshooting What do I do if the RF mouse does not work? • Make sure that the polarity of the batteries is correct. The positive (+) and negative (-) ends of each battery must match the positive (+) and negative (-) connections in the battery housing. • Check that the receiver’s USB connector is firmly attached to the USB port on your computer. • Verify that the device drivers are installed. • Make sure you have established a radio link between the mouse and its receiver. See “Establishing a Communications Link” in sections above
Feb 08, 2010 | Targus Wireless Optical Notebook Mouse...
Mouse wondt work lights are on
Was the adapter recently removed or batteries changed? Try resyncing the mouse with the receiver, there should by a button on both to do this
Oct 07, 2009 | Targus Wireless Optical Notebook Mouse...
Wii Remotes will not resync after using friends Fit Board
there is a flap in the wii open it up. open the spot where the batteries go on the controller. the controller and the wii should have a orange butten press them both at the same time.
Aug 20, 2009 | Nintendo Wii Console
Targus amw15us not working
have you tried to change batteries? low battery will cause your mouse not to connect to the receiver.
Feb 04, 2009 | Targus Wireless Optical Notebook Mouse...
How do i sync the mouse and the keyboard with the computer?
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Jan 13, 2009 | Key Tronic Cordless (unplugged-ps2sb02)...
I forget how to connect my targus presenter to the usb device. What sequence do I push the connect buttons?
To Reconnect the Device and the Receiver :
Position the Power Switch to “Presenter” mode to turn on the presenter.
1 This presenter is a plug and play device and should work once the USB receiver is connected to and recognised by the computer. If the device is not working or you have recently replaced the batteries, you can try to reset the ID code between the receiver and the remote. To do this, do the following:
2 Once the computer has recognised the device. Press the
connection button on the receiver.
3. After the connection button is pressed on the receiver, press the
connection button on the back side of the presenter.
The devices are paired and ready to use.
Or check from page 5 on the USER GUIDE
Dec 17, 2008 | Targus (AMP0205USZ) Remote Control
Targus mouse remote
Feb 07, 2008 | Targus Wireless Remote Presenter Mouse
Lost instructions
This solution works for both TARGUS MODEL: AMP01EU and AMP01US (AMP01U AMPolu AMPolEU)
1. Connect the TARGUS reciever to the USB port on your PC.
2. Let it install 'the human interface thing...'
3. Reboot the PC (Windows 2000 and Windows XP)
4. Put fresh batteries in the handheld trackball thing (=the remote)
5. Switch the power switch on the handheld remote from OFF to ON
6. Verify that the green LED is now alive
7. On the reciever press the little button besides the enlightened RED LED to turn it off.
8. On the remote - PUSH the little hidden button on the bottom between the LASER pushbutton and the battery cover multiple times until the RED led on the reciver turns on again. (= We have now connection!)
9. SHAKE mechanichally the remote, so you hear some clicking noise from the remote.
10. Verify that the mouse cursor on the PC screen now can be controlled from the remote.
Please post here if it works or not for you.
A shorter version:
Turn the REMOTE ON
SHAKE IT FORCEFULLY
DONE.
Jul 31, 2007 | Targus AMP01US Remote Control
Targus (AMP0205USZ) Remote Control Logo
445 people viewed this question
Top Targus Televison & Video Experts
Electro Med Services...
Are you a Targus Televison and Video Expert? Answer questions, earn points and help others
