Question about Dometic Heating & Cooling
Filter is clogged and needs cleaning, we would like to know how to do it ourselves
  • 8,404 Answers
Take it out ... wash it in the shower ... shake out the excess ... return it to its holder.
Posted on Sep 29, 2010
Clogged filter screen
Look here - your's should be similar. If not, please tell us your model number. https://www.youtube.com/watch?v=GUZPNlYCMqc
Apr 10, 2014 | Whirlpool Dishwashers
LG DLEX2901V
How long is the vent line from the rear of the dryer to the outside?
Nov 05, 2012 | Dryers
Cold water hose connection filter clogged up - how to clean out
Are you referring to the conical shaped screen in the end of the hose that connects to the water supply? If so, it can be removed using a sharp pointed instrument such as a small screwdriver. Then it can be cleaned by flushing it from the back side.
Sep 12, 2012 | Refrigerators
Cant get the clean filter lights to stop flashing
Think of this as a "low airflow" indicator. I know it says clean filter, but this error code is triggered when the temperature gets too high in the air duct sensor at the front of the machine as compared to the sensor at the rear of the machine. the most likely cause is a dirty filter. if you use dryer sheets, the fine mesh can get clogged with paraffin wax. if you hold your filter up to the light, and it looks cloudy and clogged, clean it in hot water to dissolve the paraffin.
if the light still comes on, check to make sure your ducting is not clogged and that the flapper door on the outside of your house where the duct exits is clear and that it opens when the dryer is running. you may need to unplug the dryer if the clean filter light is on and wont go off. plug it back in and try to run it.
Jul 09, 2011 | Miele T9820 Gas Dryer
Sub-Zero 680/F The fridge is flashing "service"
Not filter but condenser coil thathe is next to compressor. Clean it out then check unit operation
Jan 26, 2018 | Sub-Zero 680 / F
I am experiencing some (not complete) loss of sunction when I use the hose
Possibilities:
Dirty filter, needs cleaned or replaced.
Partially clogged hose, needs cleared. Detach hose from tank and drop marble down the end of the hose. It should roll through the hose and power head to the floor.
Partial clog in the power head between where hose attaches and the brush. Detach hose from power head and drop marble into opening. If the marble doesn't roll through, there's a clog that needs removed. You may need to disassemble the power head to do so.
Leaky hose, needs replaced.
Clog between back of tank and filter. This is where the hose attaches to the tank. Remove clog.
Clogged filter at bottom of tank, needs cleaned. Remove tank. There's a screen at the bottom of the tank/vacuum. Simply remove/clean anything that may be covering/clogging any of the holes.
Dec 18, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Kenmore Elite HE want to know where the filter is so it can be cleaned top load, super capacity, have a clean machine cycle, but is there a filter that needs to be cleaned periodically?
most just have a lint filter at front of machine they should be cleaned after every load and chect where dryer vent goes outside wall of house see if it is clogged with lint clean that out as well
Dec 26, 2009 | Kenmore Elite HE4 Electric Dryer
Clogged filter??
You can try to clean out the pic and glides on the K-cup receptacle. Let me know if this works. It should.
Mar 03, 2009 | Keurig B50 Coffee Maker
Hi, we have a problem with our Canon Pixma IP3000 printer. Looks like Cyan and Magenta nozzles are badly clogged (countless cleans and deep cleans did not make any difference). I would admit that it was...
I use an ultrasonic bath for clening badly clogged nozzles. You can also try soaking in warm water for 15 mins. If this doesn't help then you might have to get a new head.
Dec 02, 2008 | Canon Office Equipment & Supplies
Heating & Cooling Logo
22 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
