Panasonic Viera TH-42PZ80U Plasma TV Logo
Posted on Sep 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flashes code 10 - Panasonic Viera TH-42PZ80U Plasma TV
Chi Chu
Level 3:
  • Panasonic Master 8,457 Answers
  • Posted on Oct 02, 2010
Chi Chu
Panasonic Master
Level 3:
Answers
8457
Questions
0
Helped
2821132
Points
26282
Replaced the power supply board,it dead.That the board,where the power a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbush power supply board for the replacement.
Flashing light #1 on the display of a 2004 recon es Honda atv
How many blinks on the 1st gear light? Here's the code definitions that should be for your quad.
Code 0 (no flashes) - The system is functioning normally
Code 1 (one flash) - Electronic control unit
Code 2 (two flashes) - Shift Switch or it's circuit
Code 3 (three flashes) - Angle sensor or it's circuit
Code 4 (four flashes) - Gear position switch or it's circuit
Code 5 (five flashes) - ECU motor circuit (defective ECU)
Code 6 (six flashes) - ECU failsafe relay circuit (defective ECU)
Code 7 (seven flashes) - ECU voltage converter circuit (defective ECU)
Code 8 (eight flashes) - Angle sensor, control motor, ECU or circuit
Code 9 (nine flashes) - Angle sensor, it's circuit or ECU
Code 10 (ten flashes) - Pulse generator or it's circuit
Code 11 (eleven flashes) - Speed Sensor , it's circuit or ECU
Code 12 (twelve flashes) - Gear position switch, it's circuit or ECU
I hope this helps you out.
Oct 08, 2013 • ATVs
2helpful
2002 dodge intrepid sxt 3.5l. what does 10 flashes of check engine light mean?
Are you sure is not 5 flashes with a short pause in between and then 5 more flashes? Code 55 indicates the end if the diagnosis.
1991 mercury sable air bag light flashes 10 times then pause and 10 times again etc?
You should be able to disconnect the battery for a minute or two and clear the code if you think it is fixed.
Set won't turn on, 10 red flashing lights
This is an error code and depending on brand/model number can have a number of meanings---
You can GOOGLE the model number with "error codes" etc to get an idea of what likely your error code means.
10helpful
2answers
Explain how to flash nokia 7210supernova mobile
To flash the phone, there are some equipments, software,firmware etc should required.If you are a mobile tech using Jaf Open Jaf emulater select bb5 connect the phone with particular fbus cable and clicj check(CHK)after connecting select manual flash,factory setting,use ini wait for 10-15 sec.there you have seen a tap.scroll and choose the particular model.Again select the product code if not available just select greater p.code.Last click FLASH button it'll take 10-15 minutes.If any message comes click YES.
Aug 11, 2010 • Nokia 7210
1helpful
2answers
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • 0helpful
    BJC-8200 beeps 10 times and wont go online.
  • Hi
  • All The Best: Pineworks
  • 2helpful
    Trouble code (MIL) reset
    just 10 flashes means that the OBD readiness monitors have not all been set.. when the battery was disconnected it reset the monitor status to not ready..
    1helpful
    Engine light fr ash 10 time
    what your check engine light is doing is called the key dance.
    The "Key Dance" is a coined term to identify a process of reading MIL fault codes stored by your cars engine computer (PCM). You cycle your ignition key from off to on (not start) 3 times leaving it on. You then count the number of times the Service Engine Soon light flashes. This combination of flashes identifies a fault code. For example, a code 21 would be flash, flash, pause, flash. All codes are 2 digits. Multiple codes are seperated by longer pauses. It should end with a code 55 indicating the process is finished.
    Sometimes in newer models, the code is shown on the trip odometer. They would be P codes.
    I would pull out my obd code reader and find out what it's telling me. Some parts places (Autozone, O'Reilys, etc) would even have a code reader you could borrow to check for any obd codes.
    2answers
    Remove a flashing code
    E62:10 errer related to lens unit problum i think some internal dislocations or gears problum this is repairable
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
