Question about Toshiba Televison & Video
I have a Toshiba RD-XS52SU HDD?DVD Video Recorder that won't turn on (in spite of green light indicator after a few seconds). Nothing is displayed on the LED screen, and no indicator lights illuminate for DVD/HDD/TM SLP. Is this a motherboard malfunction, or is there someway to reset the boot cycle.
  • 3 more comments
  • jtenbusch May 24, 2008
    I've tried this remedy repeatedly. No good.
    Already went through owner's manual. Nothing useful there.
    Tried many different outlets. That's not the problem. As I said, the green ready light does come on from the red "standby" state. The LED clock continues to work, but none of the panel buttons work. Can't open the DVD drawer. Pressing the input button results in nothing. Pressing any one of the function buttons for HDD or DVD or TMSLP results in nothing.
    No.
  • jtenbusch May 25, 2008
    Nope, didn't help. Anything I can do inside the box?
    Genius:
  • 3,422 Answers
You can try out a hard reset first by unpluging all the cords from the back for 30min and then put them back.
Goodluck..
Posted on May 24, 2008
  • 3 more comments
  • Priya darshan May 24, 2008
    See if the light don't turn on it can be an internal issue with the dvd itself which can only be fixed by repairing it.Anyways did you try plugging the player into a different outlet?Just give it a try?
    Is there any dvd stuck inside?
    ok now there is only one home remedy you can try.Turn the player upside down and then hit 2 or 3 times a little hard.If this doesn't help then the only solution will be to get it repaired.
  • Priya darshan May 25, 2008
    Please don't forget to rate or accept the solution
    Inside the box?Nope nothing can be said what can be wrong but if you want you van try removing the top cover and check for any loose connections of the wire.If there are any then you'll have to solder them up.But i strongly recommend you not to do this.It is better to get it repaired.
    If you need anymore help let me know..
    Please don't forget to rate the solution
    Genius:
  • 1,665 Answers
Hi have a look at your service manual for troubleshooting
http://www7.toshiba.com/secured/tass/technical/dvd/RDXS52SVM.pdf
Toshiba RD-88DTKB won't switch on
Check the capacitor in the power supply board, if defective it will show a slight bulge at top, value should be around 1000uf give or take, if handy with soldering iron replace with same value and voltage rating.
Jun 05, 2012 | Toshiba Televison & Video
I have a recorder that whenever i put in video cassettes stops playing after a few seconds and turns the unit off. Can anyone help. Thanks
sounds like belts and rollers and any sensors you see need to be cleaned - it sounds like the unit thinks tape is at end and is shutting down
use qtip and rubbing alcohol to clean
try using different tape just to make sure it is not just a bad tape
Mar 21, 2011 | Toshiba RD-XV49DT DVD/DivX/VHS...
Toshiba RD-XS35SC error 14 flashes constantly
Press the "Display" button a few times to clear the error.
Dec 12, 2010 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Trying to dubb video from hard drive to dvd-r and error 14 keeps coming up on the screen. thanks sylvie
Well, by now I'm sure that you know to clear the code, you press the "Display" button a few times. As for getting the Toshiba to actually burn a DVD, I'm not certain that I can help you there, as I've run into problems burning stuff. Unfortunately, it doesn't burn all the time, even if you use the same routine as the last successful burn.
Sep 26, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba RD-KX50 HDMI freezes the recorder.
Press the standby button for about 10 seconds and will reset the HDD you may lose what you have on the HDD but will fix it.
May 07, 2008 | Toshiba RD-KX50 DVD Recorder/HDD Recorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
HIGH-SPEED DUBBING TOSHIBA RD-XS34
Press the 'Display' button on the remote control.
Dec 05, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Televison & Video Logo
198 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
