Question about Casio G-Shock Chronograph Series Watch AWG100R-1A Watch for Men
The analog time is wrong, while the digital time is correct. i do not know how to fix it.
    President:
  • 2,501 Answers
You can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on Sep 29, 2010
  • kcz3 May 08, 2011
    Thanks to these instructions, I'm convinced that I caused the same problem to occur as a result of pushing buttons when trying to remember how to get the time zone to change while we were on a vacation. I read the manual and adjusted the analog time. It's working perfectly now. Thank you, davidtolong!
3 Suggested Answers
dmbgo
  • 58 Answers
SOURCE: digital and analog times are different
Adjust the analogue time with the winder
Posted on Jun 22, 2009
  • 2501 Answers
SOURCE: tissot touch watch, the digital time is correct, the analog not.
You can get a set of instructions from their web site (tissot.com).
At the bottom of the page there is a menu; select "warranty" and a number of alternative PDF files appear on the left.
If you can't see what you want, select "user manual" from the menu at the top and enter the details of your watch.
Choose the one that is suitable for your watch and download
Posted on Mar 21, 2010
Testimonial: "this is the conclusion that i also came up with."
I have a disallignement of 10 minutes between the digital and the analogical time. The digital time is perfect how can I allign the analogical one?
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
May 23, 2015 | Casio WVA105HDA Wave Ceptor watch
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
I have the correct time set in the watch, the main analog clock shows the correct time, but the UTC analog hands19:00 when the UTC digital time is 12:00. How do I reset the UTC analog hour hands?
The hands are driven by the digital. It seems to me you have the wrong digital city. Please review the setting instructions for your Skyhawk at: http://www.citizenwatch.com/
BTW, I love my Titinimum Skyhawk
Aug 03, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Tissot touch watch, the digital time is correct, the analog not.
Mar 20, 2010 | Watches
New battery inserted.digital part of watch shows correct time.clockfave shows different time.also the 2 buttons on the side when pressed in do not come out again
First, take the back off the watch and make sure that the movement is inserted correctly. When buttons dont come back out it is usually the movement in the case wrong or the back is put back on wrong. If it is a pop off back then you want to be sure the dimples in the back are over the stem and crown and buttons so they move freely. Also, be sure that any springs that were in place are still in place.
Now i dont know what brand or model of watch this is but most digital analogs have a stem and crown to set the analog. Pull out the stem to the first position and set the time.
For specific instructions please leave the brand and model.
Thanks!
Sep 19, 2009 | Watches
Daylight Saving Time will not set correctly
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Casio G-Shock Chronograph Series Watch AWG100R-1A Watch for Men Logo
293 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
