Question about Husqvarna 36" Wh3615 Walk Behind Mower Zero Turn
My huskvana wht 3615 walk behind mower constantly pulls to the right how do i fix this
  • 490 Answers
The right wheel shaft may have slipped its pin, allowing the left wheel to provide more power. I had a similar problem with a DR Mower. Farmerbear at FixYa.com
Posted on Sep 29, 2010
How do I fix the speed control on an Ariens walk behind lawn mower?
do you mean the throttle cable? as its a push mower im gussing it is. If the mower is relatively new then it will be fitted with an opc (or dead mans handle) in which case there is no need for a throttle control as the engine speed is governed and should only be used at the fixed goverened speed
Apr 08, 2016 | Ariens 21 In Classic Walk Behind Push Lawn...
Tip
Safety For Walk-Behind Mowers
<span> <ul> <li>Do not put your hands or feet near or under the mower.</li> <li>Never tilt a walk-behind mower; always keep all four wheels on the ground.</li> <li>Do not pull the mower backward unless absolutely necessary. Always look down and behind before and while mowing backwards.</li></ul></span>
on Apr 02, 2011 | Garden
How to tighten drive belt on 26 inch walk behind mower or replace drive belt
Here is a video about how to replace the drive belt on a walk behind mower, hope it helps you out!
How to Replace Lawn Mowers Drive Belt
Jul 28, 2015 | Garden
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Have a walk behind 22"
Sounds like the rewind spring is broken in the recoil starter.
Aug 04, 2011 | Toro Power Lawn Mower
Model #911503 ,serial #000278 The pull
Here a couple of links with instructions on replacing your rope... Text Good Luck
Jul 03, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Recoil will not pull. The walk behind MTD,Yard Machine mower, a B&S 500 Series stalled while mowing. I went to restart and pull cord will not pull more then a few inches. How do I go about the fix?
If all the safety gear is working on the mower; Possibly sounds like you let it run low on oil and the engine is locked up.
Which would mean a new mower.
Sep 29, 2009 | Mtd Garden
Craftsman Walk behind lawnmower
usually theres just a few bolts to take off on the top, and the whole rip cord assembly will pull right out, allowing you to install the new one.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Husqvarna 36" Wh3615 Walk Behind Mower Zero Turn Logo
284 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
