Question about Jabra BT350 Bluetooth Headset Headset
I have a Bluespoon ax2 bluetooth headset which I use for my ps3 console.Recently when I turn it on it does not connect. but when i put the headset next to the ps3 and turn it on it does work but my problem is that before I could be up to 3 metres away from the ps3 and it works fine.When i do go next to the ps3 and turn it on i sound really crackly.Any suggestions?
Dont go near your ps3
Posted on Oct 29, 2008
How to connect hm1700 to ps3
Link to Samsung manual for HM1700 bluetooth headset. Need to put it in pairing mode. On your PS3, in the XMB screen(home screen), scroll over to settings, second option and scroll down to Accessory Settings. Then pick Bluetooth settings and then search for available devices. It will find and attempt to pair with your headset. Put in a code if needed.
Aug 22, 2014 | Video Game Consoles & Games
Kindly help me connect my samsung HM1100 bluetooth headset to my playstation 3
1) Go to "Settings" on your PS3.
2) Scroll down and select "Accessory Settings."
3) Select "Manage Bluetooth Devices."
4) Select "Yes" when the message "The Bluetooth device has not been registered. Do you want to register?" is displayed.
5)
Turn on your Bluetooth headset when asked by the message "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, check the instructions supplied with the Bluetooth device." While each Bluetooth headset is different, for most this means to hold down the power button until the blue light on the device remains solidly lit.
6)
Select "Start Scanning" once your Bluetooth headset is in "pair" mode. Wait for the PS3 to scan for your Bluetooth headset. If the scan was successful, your Bluetooth headset will be listed on-screen. Select your headset from the list
7) Refer to the Bluetooth headset's instruction manual to find the pass key for your device (Usually the pass key is something simple like "0000" or "1234". Press "X" to bring up the on-screen keyboard and enter the pass key. Select "Enter" then "OK." "Register Completed" will display to confirm a successful connection.
NOTE: If the headset does not display after a scan, it may not be compatible with the PS3, or it is not properly set to "pair" mode. Refer to your Bluetooth headset instruction manual for directions to properly set your device to "pair mode."
If you want to check the User Manual for your Bluetooth, simply click on the following link:
http://www.samsung.com/us/support/downloads/BHM1100NBACSTA Click on the Icon below "File" Thank you.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
Recently when i try to connect the bluetooth to my ps3 it says that a connection could not be established.Howq do i fix this?
If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Aug 18, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
PS3 bluetooth headset won't work
hello,
ive had the exact same problem
make sure that the blue tooth is in "pairing mode" when the system is scanning.
reference to the bluetooth manual to put the device in pairing mode.
I hope i have helped and I hope it works
Jan 14, 2010 | Sony Playstation 3 (PS3) Console
How do you connect the headset tothe ps3
Navigate to SETTINGS and scroll down to select ACCESSORY/PERIPHERAL settings menu, when selected scroll down to MANAGE BLUETOOTH DEVICES, follow the ADD NEW DEVICE to connect your Headset to your ps3.
Make sure your headset is turned on and in pairing mode.
now scroll down to select the AUDIO device settings and select your headset as your device, you are now ready to use your headset.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
How do you turn the bluetooth on on a ps3 cause i cant get my bluetooth headset to pair
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device
You will be presented with two options:
Register BD Remote Control
Register Headset/Microphone/Headphones
Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning
Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000"
Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
This might help you as well:)
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=898874
Dec 22, 2009 | Sony PlayStation® 3 (80GB) Console
No sound from bluetooth headset when paired w/ ps3 and audio set
the bluetooth headset is not compatible.get a compatible headset for ps3
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
Get disconnected from game when bluetooth is attached
lol faygit dumshet bluetooth sux get usb headset idiot. get a fockin better connection and better mic
Mar 04, 2009 | Sony Playstation 3 (PS3) Console
Ex-01 ps3 bluetooth headset
hi it the option when setting it up, go to thee settings screen for bluetooth equipment and change the output to headset.
Jun 21, 2008 | Sony Playstation 3 (PS3) Console
Ps3 bluetooth headset
You need to "pair" the headset to the PS3. Follow the instructions for your headset (usually holding down the power button until you get a SOLID blue light) then go to Settings>Accesory Settings>Register BlueTooth Device>Scan. When you're done, you need to set your input device to your Headset model #, which should now appear.
Feb 16, 2008 | Sony Playstation 3 (PS3) Console
Jabra BT350 Bluetooth Headset Headset Logo
360 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
