Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
My blade adjustment screw is stripped out. How do you go about changing it . Husqvarna model 345 e-series
    Scholar:
  • 111 Answers
You will probably need to replace it. Try Small Engine Warehouse for the part. Their website is
http://www.smallenginewarehouse.com/
Posted on Oct 06, 2011
How do I adjust the oiler
As standard the 345 did not have an adjustable pump, there was an option of an adjustable pump, if it has the on, then the adjuster is a three position screw comimg up from under the crankcase below the sprocket, you will see a + and - on the edge of the tank at this point.
Nov 14, 2012 | Husqvarna Forest & Garden No.967012396 345...
Unable to locate adjustment control for chain oiler model 345 husqvarna chainsaw
Not all 345 machines had an adjustable oiler, it is retro fittable if it does not, however if it hs an adjuster, the screw is located on the bottom of the saw between the cranckcase and the fuel tank, just below the sprocket, there will be an oil symbol and a - and + sign there, the pump is three position, for 13/15/18" bars.
Oct 02, 2011 | Husqvarna Forest & Garden No.967012396 345...
Bar oil adjuster is located?
Not all 345 machines had a adjustable oiler as standard, they were retro fittable, if it has an adjustable pump there will be a screw head under the crankcase below the sprocket, you will see a + and - sign on the fuel tank with an oil drop.
Sep 02, 2011 | Husqvarna Forest & Garden No.967012396 345...
I need the gap specs for my husqvarna 345!! between the flywheel and the magneto. also need screw adjustments on carb.
The easy way for the gap is to use a piece of sandpaper between the flywheel and coil.Turn the magnet to the coil with screws loose.Put the sandpaper in between then tighten.Pull out the paper.The adjusting screws just start with 2 full turns.Adjust the low side first.You just want it to rev quick.Just play with it till it does.Likely you will need to screw in in just a little.To adjust the high side just rev it about wide open.Then adjust till its running smoothest.Do this with the bar and chain on to get it just right.Other wise you might over rev it. Hope this helps
Mar 07, 2011 | Husqvarna Garden
I have a Husqvarna 345 with a 18" bar. I worked
This machine has a geared side adjust tensinor, i woud say the gear system may have striped, remove the clutch and drum, remove the allen screw securing the silver bar protector plate, the adjuster will now just lift away complete, check its function, replace if required, check the oiler is working, hold the saw over some cardboard, rev the engine and check to see if there is a good oil spray onto the card.
Jan 13, 2011 | Husqvarna Chain Saw with 18" Bar
Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Jul 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Mar 31, 2009 | Husqvarna Forest & Garden No.967012396 345...
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
345 husqvarna chain saw will not run
If it idles it is not flooding out as it it most vulnerable to flooding at idle if the stalling is happening as you try to throttle it up it is likely starved for fuel. Start by changing the in tank fuel filter, and the spark plug. good chance that will solve your problem. If it does not Turn the high idle screw out in 1/8 turn increments try running the saw after each adjustment. Keep track of the amount that you turn the screw. you might have to put it back to its original position. Some times adjustment screws will vi berate out of adjustment and other times crud will cause fuel restriction opening the screw allows for a larger port for any restrictions to pass through. After you use the saw for a short time turn screw back in if it starts to stall at idle or you notice increased smoke.
Jan 05, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna model 345 chainsaw
adjust the gas by turning the screw on the carburator
Dec 28, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
67 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
