Question about Frigidaire FWT449
My front load washer has a load clunk when the drum is spinning. If I spin it by hand I can still hear it. I took the back off and it sounds like coming from inside the drum.
  • Frigidaire Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description "My front load washer has a load clunk when the drum is spinning. If I spin it by hand I can still hear it. I took the back off and it sounds like coming from inside the drum"
my first suspicion would be a worn tub bearing, unfortunately all too common with those Frigidaire.
The tub bearing is likely worn, or the inner tub has broken apart.
You can check this by way of opening the door and grabbing the inner basket rim and moving up and down to feel for play...there should be zero play or zero tolerance in this bearing.
Second, since you`ve removed the back panel, grab the large pulley and try and move it back and forth or spin it with the belt off to listen for a grinding noise.
If it is indeed worn it will require practically the complete tub assembly ( rear wall with bearing and inner basket )...that is the least expensive and easiest fix at around $400 for the entire assembly.
example...
You can opt to change just the rear wall and bearing with the basket in separate pieces, but it comes in around $370 and still leaves you with pulling the old one apart to re-use the front shell.
Either way this is a fairly involved repair and even for an experienced tech like myself can take 60 - 90mins.
Let me know what you find and I'll do what I can to assist you.
Good luck. Thank you for choosing FixYa.
Regards,
Macmarkus :)
Posted on Sep 29, 2010
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
My Duet Washer is making loud noise during spin cycle and has plastic shavings, from front tub rubbing i assume.
Hi, it could be your drum bearings are gone the drum would wobble slightly. A way of checking is , machine unplugged put one hand at bottom front and one hand at top front edge and push up and down if it clunks quite badly then your bearings on the drum shaft are needing renewed. You also have a shock absorber for steading the drum this can also fail. The absorber is very hard to compress so if its easy to compress then it needs re-newed.
Dec 29, 2015 | Washing Machines
Replace washer spin basket kenmore elite 110
sounds like a bad bearing on the rear of the tub. If you remove the rear access panel you will see a large pulley and belt. That attaches to the inner drum (basket) and spins it. It floats on a bearing just behind the pulley. If the bearing is bad then you will be able to move it up and down about .25 to.50 of an inch.
Jun 25, 2014 | Kenmore Elite 45986 Front Load Washer
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Frigidaire GLTR1670A Front Load Washer
Something rattling under the drum
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Nov 18, 2008 | Kenmore Elite 45986 Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
"Sreeching" sound when trying to spin.
? Is the drum free to turn with your hand?closes Eire
Dec 05, 2007 | Kenmore Elite 45986 Front Load Washer
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
346 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
