Question about GE ADER65LN Dehumidifier
I have a GE ADER65LNQ1 that just arrived yesterday. Unfortunately, it does not work!. The bucket full light glows as if the bucket were full (it is empty!). When I pull the bucket out and press the button behind where the bucket slide in, the unit will operate for a few minutes. Then it will shut off and the full bucket light will glow again. Any ideas as to why this unit thinks the bucket is full. ...and yes, the bucket is fully closed when trying to start this and it is in a damp basement.
5 Suggested Answers
SOURCE: Haier Dehumidifier not removing moisture
After total frustration, we took it back to the store and got a refund. They told us so many of these have come back, they were surprised they haven't been recalled yet. Thanks anyway.
Posted on Jul 22, 2008
heatman101
  • 43501 Answers
SOURCE: My dehumidifier is about a year old. Plugged it in
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
richroth
  • 9472 Answers
SOURCE: After the bucket is filled
The sensor for the bucket is not working and is not a serviceable part. You can also run a hose to directly drain the unit to a floor drain if this is at all possible in your location. If not, I would replace the unit.
Posted on Aug 05, 2011
  • 4736 Answers
SOURCE: My GE basement dehumidifier is overheating. The
Yes, the first suggestion is I hope your dad can get it back together without any parts left over (LOL). Over heating is generally caused by an clogged or dirty air intake filter. Simply removing it and vacuuming it or if it's really dirty, washing it in warm water and mild dish washing liquid will clean it. Rinse it thoroughly, shake off excess water and allow to dry completely. Never operate the unit without the filter in place. Doing so, can damage the unit.
Getting back to the heat for a moment and where you're using your dehumidifier. Dehumidifiers do generate heat, it's not abnormal. Operating it in a basement can cause it to over heat. This happens because the air temperature at floor level is colder than at shoulder level. Dehumidifiers struggle in temperatures below 65 degrees F (unless you have a Low temp unit, designed for basement applications). Raising the unit up off the floor, on to a sturdy table, counter top, etc, that an handle the weight of the unit, plus a full bucket of water, will generally resolve the problem.
Actually, a basement application , higher is better.
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 16, 2011
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
The water full light glows and the collection bucket is empty. nothing is happening. Any suggestions. thank you
The bucket level sensor may have been moved, bent, or ? the last time the bucket was removed, dumped, and reinstalled.
Sep 11, 2012 | Daewoo DHC-400 Dehumidifier
The "full bucket" light is blinking- and the
When the Bucket Full Light is on, none of the controls (other than the On/Off) will work. If you haven't
emptied the bucket, do so. Then make sure the bucket is reinstalled properly into the holder. Failure to do this will cause the Bucket Full Light to stay ON. While you have the bucket out, check the inside of it for a float valve. It may be stick in the UP position. If so, jiggle the handle to make it return to the DOWN position.
I hope this helped you and thanks for Choosing FixYa.
Aug 12, 2011 | Kenmore 54501 Dehumidifier
Unit shows full bucket whe bucket is empty and shuts off
I beleive the model you have, has a float valve in the top of the water collection bucket. If it's stuck in the 'UP' position, it would cause the Bucket Full Light to glow. Remove the bucket form it's holder and determine if the bucket does have the float valve. If so, jiggle the float valve arm to get it to return to the Down position.
If the unit doesn't have a float valve, installing the bucket "squarely" into it's holder from top to bottom is very important. If the bucket does not make firm contact with the bucket removal safety switch (A trigger switch), it will cause the unit to think the bucket is full. After reinstalling the bucket, be sure that the bottom of the bucket is not tilted down in any way.
Hope this helped you to troubleshoot and solve the problem.
Jul 08, 2011 | Kenmore 53509 Dehumidifier
Why is the red water full light on and not worrking?
Usually, when the red water full light glows, it means that the water collection bucket is full & needs to be removed and emptied. Once that's done and the bucket is reinstalled properly, the red light will go out and the unit will turn back ON.
Jul 07, 2011 | Daewoo DHC-400 Dehumidifier
Kenmore dehumidifier # 54501.. Will not start..."01" comes up in the screen and the "full bucket" red light flashes on and off, but it is empty. put the bucket in and out many times but still will not...
According to this, a user was able to remedy the error by replacing the sensor assembly. Unfortunately, I have no idea how to do this, and I cannot direct you to a place to purchase a new part, so you may be better off getting it repaired at a local Sears retailer.
Aug 03, 2010 | Kenmore 54501 Dehumidifier
GE dehumidifier light says bucket is full but it isn't
Try feeling both sides of the outside of the bucket and make sure the bucket is flush with the dehumidifier. If one side is sticking out more than the other it may notbe engaged correctly which will cause a full bucket notification. If everything checks out ok there try takng the bucket out and push in on the button that the lever from the bucket engages on at the dehumidifier. If the light turns off after you push on the red button that means the bucket is not engaging correctly. If the red light stays on and it doesnt make a difference he button sensor may be defective. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 19, 2008 | Dehumidifiers
GE ADER65LN Dehumidifier Logo
212 people viewed this question
Top GE Dehumidifiers Experts
J.D. Browning
J.D. Browning
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
