Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
Saeco coffe maker doesn't work
The "fill watertank/ventilate signal will not turn off, even though the machine has been primed and the tank is totally full.
  • RMichaud Jun 24, 2008
    Hi I'm also having the same problem. What was the solution?
    Ryan
  • BOUTIK35 Jul 11, 2008
    i have the exact problem the ventilate will not shut off and the machine is prime and a full tank, and also when i try to ventilate nothing hapen no water comming out from the steamer. looking for a solution please
Thank you for your concern! I drove it over to place nearby that fixes these machines in Los Angeles. That way, I can avoid costly shipping charges!
Posted on May 26, 2008
  • 515 Answers
  1. Make sure the steam pipe is clean.
  2. If you open the stem knob, can you get a cup of water or just a half cup?
if you only get a half cup then you have to replace the "water turbin" that is a water counter.
Make sure to descale the machine regulary
Posted on Jul 12, 2008
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
I've got a problem with my Saeco Vienna Digital. It says that I've got to fill the watertank and ventilate. But the watertank is filled, that little 'thing' in the corner of the watertank is still going up...
Check the end of the steam wand it might be blocked, if it is not, then remove the steam wand and check the top there is a small teflon insert (this part is in some models) remove insert and toss. If that does not solve problem then machine needs to be descaled.
Jan 12, 2010 | Saeco Vienna Digital Coffee Maker,...
When i turn the machine on the screen says fill watertank. ventilate. the tank is full. i replaced the water level sensor. it still doesn't work. the magnet in the watertank is floating. any other ideas?
gnet goes in the slot. Flat side up. There is a cap that is rectangular in shape that holds the magnet from floating out. We use a tiny drop in the corner of the cap( I mean tiny) in place. That should correct your message.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Aug 23, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Royal Exclusive 30153... FILL WATERTANK
Hi Marty,
Make sure the magnet in the water tank flow up when you fill the water tank with water.
Aug 07, 2008 | Saeco Royal Exclusive 30153 Espresso...
Red alarm light permanently on!
Hi.
First turnthe machine on.
Then take out everything watertank, dreg draw and brewingunit and have the door opened to the brewing area.
have them out for about 1 minute and then put it back together again.
if this dosent help please check if the machine respond to removing the dregdraw, beanlid.
It will do it by making the constant red ligth flash instead.
if they respond make sure that the watertank is filled to max.
if that is the case it is the watertank sensor that is broken.
May 26, 2008 | Saeco Odea Giro Espresso Maker -...
Saeco Stratos; when i start the machine it goes on energy saving and when i push again it start the purge cycle but stay block there.
I got this coffe machine, but when I turn it on is says watertank is empty, but in watertank is a lot of water. I try input this watertank a lot of times to that machine but I have still same problem... I will die withou coffe, heeeeeelp...
Apr 21, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
350 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
