Question about Hitachi 50UX57B 50" Rear Projection Television
I have waves running up my screen how do i fix that
  • 130 Answers
Hi
depending on the waves if it is light dark bar rolling from bottom to top it may be a defective
capacitor in IF section or interference comming
for ex:defective neon sign leaky electric power transformer etc. If it is a slow moving
wave but no bars you have a defective power suply regulator and I don't suggest you try to fix it yourself
Posted on Sep 29, 2010
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
I have samsung wave 3(gt8600) that switch off itself and switch on itself without stopping. It will stop only when i remove the battery. I treid to solve through samsung kies but nothing helps me why bcoz...
Hi there, this is a problem with all the Wave 3's, it's quiet dissapointing as there software cannot cope. The only way I managed to fix mine was by deleting unwanted items so as to reduce the memory and then let the battery run totally flat and recharge it over night. It seems to hold out for a good few weeks after that but unfortunately does start doing it again. Hope that help's a little.
Apr 08, 2014 | Samsung Wave 3 S8600
Twister Mania start up issues
Make sure to run the Kinect setup and calibration in the Xbox 360 Dash. Move all the way to the right and select kinect settings. Run the setup and follow the instructions there. Make sure to have a Kinect setup card handy. (comes with games.) This should help with any calibration issues. If that doesn't work, try signing in with a different account, or doing an xbox live sign in test.
Jun 01, 2012 | Majesco Twister Mania X360 Kinect
When I turn my ps3 on I only can see the waves and the brighte dust form the screen but it doesn't show the menu just that
There are many reasons cause PS3 hang up in wave screen and won't turn on. Your PS3 hardware need some kind of fixes. Send back to Sony is expensive. You better repair by yourself. I suggest you bought this guide, you can learn how to trouble shooting and disassembly your console and fix it at last. Good luck!
Oct 01, 2010 | Video Game Consoles & Games
When turning on ps3 purple screen with waves
Same prob my ps3 stays on the purple waves then won't load the main menu
Aug 31, 2009 | Sony Playstation 3 (PS3) Console
Wave in my LCD Flat Screen
try a dvd on your tv.sounds like a signal source problem.if you see the wave playing a dvd then you have a defective digital main pcb or the panel is going bad.
Jul 17, 2009 | Toshiba 42HP66 42 in. LCD Television
Convergence Projection tv
Explain the wave. Do you mean your video is shrinking then expanding. If so www.magnavoxhelp.com has a kit that will fix this common problem.
Jul 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Fuzzy page continious.
Yeah I just read a tip. There seems to be a problem with the wave amp board, I will send you the engineering note. Sometimes though that encoder needs replaced and cleaning is not the total fix. The encoder may need replaced, but I found this also.
I just received this, this morning.
Failed Wave Amp
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Historically blurry print was caused by oil on the drum encoder wheel. This can be caused by the wave amp board. A cracked capacitor on the board causes the wave amp to produce a malformed amplified wave signal to the printhead. This in turn causes the printhead to eject ink at the wrong times, so the prints look blurry.
You can generally distinguish a wave amp problem from an oily drum encoder. The wave amp problem will usually be an infant failure. The printer will start producing blurry prints soon after it is installed and running. With a failed wave amp all prints will be blurry with no improvement. The drum encoder, on the other hand, may produce good prints and then bad prints and then good prints. Blurriness changes depending on how the oil is interfering with the encoder.
May 05, 2008 | Xerox Phaser 8500/DN Printer
Faulty screen
You might need to replace the surface mount capacitors. measure the ESR on them, the higher it is, the more likely you are to get ripples. If this doesn't say much to you, take it to a lab. Use the warranty if you have it offcourse. Good luck
May 05, 2006 | HP D5060A (White) 14 in. Flat Panel LCD...
Hitachi 50UX57B 50" Rear Projection Television Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
