Question about GE Dishwashers
The soap in my "smart dispenser" appears to have turned partially into a gelatin surrounded by liquid. Our dishes do not seem clean lately, and I just realized that the red light (to indicate that the soap level is low) has not come on in some time. What is wrong? The above problem refers to my GE Profile Dishwasher with the model # of PDW9980N20SS I have only ever used the same soap which is Cascade Complete liquid dishwasher detergent, as recommended in the owner's manual. The only other thing that I can think of is that we went on a long vacation in the summer. Maybe the soap turned to gel in that time frame? Am looking forward to your guidance asap.
I have the same problem. It isn't because of a long vacation, so if its still under warranty, call them out before they try to charge you an arm and a leg!
I called GE, they told me that it was Cascade's fault because they changed their formula to phosphate free and when I refilled the smart despenser, it congealed. When I called Cascade, they offered to send me a voucher for a free container of Cascade and they gave me a number to call GE saying that I wouldn't have to pay for the service call and that they would walk me through how to get it cleaned out. I then called GE and I was told by GE that I will have to pay the $100 for them to even come out and look at it because I have owned it for 14 months. (2 months past the warranty.)
I am still calling back and forth telling them both that I shouldn't have to pay for a service visit because I used the recommended Cascade detergent and it clogged it. Both of them are finger pointing.
I am in the process of trying to clean it out myself without taking it all apart, and its not looking like it will work. I had to get a wet vac and **** it all up, put water in, slosh it around by moving the door up and down, and by pushing a long straw in trying to break up the clotted detergent.
Good luck. If I find anything that will for sure get it cleaned up, I'll post it on here!
Posted on Oct 06, 2010
  • 901 Answers
Open the soap filling door or knob. Keep pouring hot water into it.
Not very hot. It will get dissolved. Repeat till you are clear with the
problem. Try wash without load after this!
Once clear you can proceed as usual.
Posted on Sep 29, 2010
  • sparky1026 Oct 20, 2010
    I have the same congealed detergent problem in my smart dispenser. Calling GE does not help. Did anyone try the Hot water flush in the smart dispenser? Did it work?
  • Gunga22 Oct 30, 2010
    Glad I found everyone's posts....what a mess. I found the hot water did not dissolve much. But I rigged a small tube on my shopvac that I was able to work into the dispenser and it broke up some of the pieces and other pieces it pulled to the opening and I used my hands to get it out. I am pretty sure I have it all out. My refill light is on now. I might buy a mechanics mirror just to make sure. I saw on a another blog there is a way to use the controls to force purge the system. I will try that next. I am not using Cascade products anymore.
Soap dispenser on my Miele G646 Sci Plus doesn't open every time. Have cleaned the washer, run a full hot cycle with the washer empty; I always ensure the dish and surrounding is dry before inserting...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 12, 2011 | Dishwashers
Dishes not geting cleaned. Soap is left in the door dispenser only partially used.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Dec 13, 2010 | Maytag Dishwashers
Dishes not getting clean
Are dishes too greasy!
Check incoming water for free flow
Add correct quantity of soap as per manual. Use dish washer friendly soap. Fill rinse aid liquid in the dispenser meant for it.
Select a different cycle programe and give a try.
May 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Mar 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
I have a Grohe dish soap dispenser that get clogged-? soap
Dilute the soap you use by 1/3 . this won't affect the soaps ability to clean, but it makes it easier on the dispenser.
Jan 16, 2018 | Whirlpool GU2400XTP Built-in Dishwasher
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Dec 05, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwasher not cleaning well
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Feb 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
483 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
