Question about Cell Phones
Quota usage warning - Cell Phones
ow to remove Quota usage warning
Posted on Dec 18, 2010
My monthly availability is 500mb which i exceeded this month. My usage is only for phone calls. I culdnt have exceeded the quota
This could be due to a number of things. I'm going to assume your phone is the only one on this plan. Most smart phones have a way to check your current data usage from the settings menu. Check there if you have an IOS device it would be under Cellular. Depending on your carrier you may be able to download an app which will allow you to check your current data usage.
Aug 05, 2017 | Cell Phones
My email is not working help me
Normally most email issues can be resolved by some basic checks to make sure that the settings are correct. In summary we just need to double check a few settings which are very easy to do & can be summarized as:
1. Check Nameservers
2. Check Billing is up to date
3. Check Password for email address
4. Check Email Account Quota
5. Check if disk usage is exceeded
6. Check Configuration
7. Try Server-Name in place of domain name
These steps are detailed below - please take care to go through them in order, they should only take a couple of minutes:
1. Check Nameservers - Check that your domain name is pointing to the correct name servers where your email is hosted.
- if you check your welcome email from when you signed up to your hosting service you will find the correct settings. If you do not have the settings then please ask our 24 hour support team & they will confirm for you.
2. Check Billing is Up to Date - If your Nameservers are correct, please double check that your hosting is paid up to date by logging into your Billing Area
3. Check Password for Email Address - Check that you have the correct user name and password for your email account. The username should be of the format" email_ID@yourdomain.com", and password is case sensitive. The quickest way to check this is to login to your Webmail. You can do this by going to http://www.ENTERYOURDOMAINHERE.com/webmail
(Please replace ENTERYOURDOMAINHERE with your domain name).
You are then prompted to enter the email address & the password. If you are able to login to webmail then this means that the password is valid for that email address so we can proceed to the next step.
3. A. Reset Email Password if Necessary - If your password is not accepted then this just means that you need to login to your Web Hosting Control Panel & reset the password for your email address. To do this, all you need to do is to login to your web hosting control panel & select the "Email Accounts" icon & then select the option to change your password. The following link shows you exactly how to log in to your Web Hosting Control Panel.
4. Check Email Account Quota - Next we need to check if your email quota is full because if this is happening then that will stop new emails from being accepted on the server. To do this, login to your web hosting control panel (see point 3 A above) & select the "Email Accounts" icon & then go down to the list of email addresses & you can see a summary of email accounts & the quota for each. If your email account is full then you just need to either delete some emails via webmail (see point 3 above) or you can simply increase the disk space quota for your email address by selecting "Change Quota" (we do not recommend setting to unlimited if possible).
5. Check if disk usage is exceeded - If your email client doesn't let you connect to the server and throws at you a 'login failed/incorrect password' error, you are likely to have exceeded your disk usage. It's not the quota of any specific email account that has gone over the limit, but the disk usage of your entire hosting account. You should regularly keep an eye on your disk usage to ensure it always stays within the limit. Steps on how to find the disk usage.
You can confirm if your disk usage has been exceeded by simply trying to login to your cPanel. If it is over-quota, cPanel wouldn't let you in. You could then contact support who will look into it for you. Once you have verified that your nameservers, billing, password & quota details are correct we can now run through some trouble shooting to find out where the issue is.
6. Check Configuration - For your email software to be able to send & receive emails then the configuration settings need to be set as shown below. You can find these settings in your emailĀ“s software. For example, in Microsoft Outlook or Windows Live Mail you just need to select Tools/Accounts & then in the Servers tab please ensure that your settings are:
> E-mail Address: Your complete email address (see point 3 above)
> Password: Your email password (see point 3 above)
> My Incoming Server is a: POP3
> Incoming mail server (POP3): mail.domain (eg: if your domain is abc123.com your settings would be mail.abc123.com)
> Outgoing mail server (SMTP): mail.domain (eg: if your domain is abc123.com your settings would be mail.abc123.com)
> Remember password: Select Yes by ticking the box to confirm
> Server requires Authentication: Select Yes by ticking the box to confirm
Then select the Advanced options and check the following:
Outbound SMTP Port: 25 or 26 [Some ISPs block port 25 traffic to reduce spamming. If you are unable to send out mails through port 25, try port 26. ]
Inbound POP3 Port: 110
Do not select the option to leave a copy on the server as this will eventually fill up your web space if you select this option.
7. Try Server-Name in place of domain name - Still not working? OK, it could be that your ISP does not recognize the mail server settings so we will try replacing these one at a time with the main server-name of the server.
To do this please follow these steps:
A. Get your server-name from the product welcome mail.
B. Go back to point 6 above & first replace the incoming mail server (POP3) with the nameserver (i.e. using the example in the above article, we would replace mail.abc123.com with node005.hostingseries.net). Try again.
C. If it still does not work change the incoming mail server (POP3) back to its original setting (eg: mail.abc123.com) & then change the Outgoing mail server (SMTP) to the server name (i.e. using the above example we would replace mail.abc123.com with node005.hostingseries.net) & try again.
D. If it still does not work, please change both Incoming & Outgoing to the server-name (i.e. using the above example
we would replace mail.abc123.com twice with node005.hostingseries.net)
If you still are unable to configure your email, please contact our support team (use the 24 hour live chat service - top right hand side of our website) and they will be able to identify the issue for you.
Nov 21, 2016 | Miscellaneous
Unlock code
quota usage warning alcatel
Jul 16, 2013 | Nokia 2626 Mobile Phone
When I turn on my phone it brings quota usage warning
first of all : Quota Warning refers to the maximum limit of server disc space reached..
so, on phones, it refers to the maximum saved something - I do not really know.. hahaha..
a. try going to your WAP BROWSER, then clear the cache and cookies..
b. then turn off your phone, and turn it on again.. the warning should be gone by then..
it worked for my phone.. if it doesn't work, I would NOT RECOMMEND TO THROW YOUR CELLPHONE OUTSIDE THEN SHOUT LIKE HELL.. please be patient and better ask your mobile carrier center..
~kyle - Philippines~
Jan 11, 2011 | Cell Phones
What is quota usage warning? im using karbonn k570 i get this warning as i switch on my mobile what to do
hello,
dont know if this is right place to post but anyways...
my cell phone when ever i switch it on gives a message "quota usage warning" with seconds countdown to 10. i generally click "ok" and it works alright.
due to which i am not able sms............
Jan 01, 2011 | Cell Phones
AS I TURN ON MY PHONE,QUOTA USAGE WARNING APPEARS AND COUNTDOWN FROM 10 TO 1.
it worked for my phone, though.. if it doesn't work, I would NOT RECOMMEND TO THROW YOUR CELLPHONE OUTSIDE THEN SHOUT LIKE HELL.. please be patient and better ask your mobile carrier center..
Sep 27, 2010 | Cell Phones
Wen i torn on my 6300 chia phone a white screan an
it means that you have so much files on the phone such that the quota allocated to the phones ram is not getting enough as it should. i will recommend formating it if it is a genuine phone ( i can help so do let me know)
On the other hand you can have it flashed by a phone technician
good luck and do let me know if you want to formate so i can give you the steps involved
Jul 05, 2010 | Nokia 6300 Cellular Phone
Quota problem
my bet will be to try have the firmware reflash or upgraded not to sure about the clones......but try a mobile service center and see if they can help you out.
Mar 15, 2008 | Nokia N95 Cellular Phone
I have the cect p168 quad band cell phone and i cant send or receive pic messages on my phone. i am also having a hard time downloading music to it. what do i do???
I have an answer and a question. First, I had the same problem with downloading stuff from my computer to my phone. I looked on the net for an answer and I found one. http://youtube.com/watch?v=kHFXnHrGmuQ. Since then I can download music and what not to my phone.
As for turing on the bluetooth go to entertainment, extra, bluetooth, and power on.
Now my question is how do I get into my MMS? More precisely, how do I delete the messages when it says that I don't have any in my inbox/outbox? It says in the pop up that there isn't enough MMS storage. In the memory status it says there are 5/100 for usage, 120K for used space, and 0 Bytes for free space. I only sent 1 MMS message and I have 1 missed MMS.
And another thing, when I turn off my phone and turn it back on the screen says "quota usage warning" or something like that and has a timer. I click ok and I am able to access my phone. But how do I make that stop coming up?
Mar 07, 2008 | Cell Phones
Cell Phones Logo
482 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
