GOLDSTAR AIR CONDITIONER WG 5004
My air con is having problems with pushing out cold air and the front part of the air con (the coil behind the mesh air filter)begins to turn into frozen ice.
I dont know what to do!
thanks
joe beate
  • 3,037 Answers
The device is most likely low on refrigerant, you need to have it charged which means, more needs to be added. This could also be caused by inadequate air flow but most likely the refrigerant is low because of a leak and only a certified repairman can usually fill them and fix them. If you continue to run it the way it is, you will most likely damage the pump. Please let me know of any other questions you may have and I would be more than happy to answer them.
good luck on getting this fixed
Posted on May 24, 2008
    President:
  • 2,712 Answers
You will have to clean out the air filter.
Hope that helps! Should you have any further questions, please post them here.
If you are satisfied with my solution or have no further queries, please take a moment to "Accept" this solution.
Thank you for using Fixya!
Cheers!
IrishDruid
  • Swilin Sampson
    Swilin Sampson May 24, 2008
    Please read THIS article as well. It will give you exact procedures to resolve this issue without the need to call a repair guy :)
How can I change air conditioner filter?
Should only be a fine nylon mesh screen behind the front panel. Unclip the front panel and remove screen then wash with water, let dry and replace.
May 09, 2015 | Samsung Heating & Cooling
My aw0893l air conditioner does not get cold. do i need freon?
Well first off is the compressor running? When you turn on the unit the fan will start. Turn the unit on to fan only. Then turn it into the cooling mode do you hear something else start? That would be the compressor. Remove the front panel so you can see the cooling coil (evaporator ) if it is freezing and has frost on just part of the coil top or bottom you have lost Freon or a system restriction.. One of the major problems with air cons is a very dirty or plugged condenser coil, which is the outside coil. If you have cotton wood trees in your area this is probably the problem.
Hope this helps Lynn
May 29, 2014 | Samsung AW0893L Air Conditioner
My goldstar R2403 doesn't seem to be pushing out as cold as I feel it should we just had the unit refirbished and they claim it was running ice cold sitting on the bench in repair shop, however we have...
The link below is for the Owners/Service Manual for your model Goldstar AC unit. It should be of tremendous help in troubleshooting and solving the problem. Either by you. or your maintenance man.
http://www.appliancefactoryparts.com/content/pdfs/118630.pdf
Hope this helps you.
Jul 20, 2011 | Goldstar R2403 Air Conditioner
MY GE ROOM AIR CONDITIONER AGH08AJG1 SWITCH BETWEEN COOL AND FAN EVERY 5 MINUTES APROXIMATELY NEVER SATYS COOLING UNTIL THE DESIRED TEMPERATURE IS REACHED
Check and clean the filter if found to be dirty. It is usually behind a decorative panel below the cold air output grates (when the cold air is on the top front).
The filter is behind the large, rectangular, slotted front panel. The evaporator coil is behind the filter. The fan behind the evaporator pulls the room air through the filter and evaporator coil where it is cooled and dehumidified. It is then discharged through the grates on the top of the front.
Direct the airflow from the unit up and away or left / right to prevent the cool air from being drawn in the front of the unit (this is where the thermostat sensor is located). Use the highest fan speed to help force the air away from the intake, too. Inspect the condenser and evaporator coils (condenser is outside and evaporator is directly behind the filter. Clean if dirty or icing over. Be sure to install a filter if none was present. There are products made specifically for cleaning between the fins of the condenser and evaporator coils. Use them only as directed.
If these suggestions do not work, you may have a problem with the thermostat, refrigerant level, condenser or condenser fan.
Jun 22, 2011 | Heating & Cooling
Works and appears to blow out semi cold air, but not cold enough to cool room down......
Hello, first thing is check the condition of the filter on the front of the unit, if it is dirty wash it and let it dry then reinstall it. Also, it is a good idea to clean the evaporator coil with a can of coil cleaner that you can pick up at any heating and cooling store. Just spray cleaner on evaporator coil and let it dry. If this does not solve the problem tjen the unit might be undercharged and will need a hvac tech to recharge it.
Apr 27, 2011 | Goldstar KG6000R Window Air Conditioner
Hi I have a Daytek 12000btu. The air con is blowing out cold air but despite having all windows and doors closed the cold air is not circulating around the room. Its only cold when you stand in front of...
air filter, cooling coil and blower wheel are full of dusty. Clean it. And also check RPM of indoor fan motor. If less replace capacitor. If rpm o.k, after clean run the unit. Thanks.
Feb 09, 2011 | Daewoo DSA-122L Air Conditioner
Not blowing cold air
There is a problem and you or an Ac technician has to find it.
Jul 08, 2009 | Goldstar R5050 Air Conditioner
AC not blowing Cold Air
take ac cage off or ac out of window so insides are exposed take out side and use water hose and clean out side coils and in side coils dont bend these coils or u will be sorry,,,clean out good if not stoped up have freon put in
Jul 03, 2009 | Goldstar M5200R Air Conditioner
Air conditioner is freezing/icing up inside
needs to be taken apart and clenaned
Jun 21, 2009 | Heating & Cooling
LG LWHD8000RY6 Air Conditioner Not Cooling Room
Remove the front cover of the unit to expose the cooling coil. Put the unit on and observe if there will be formation of frost (ice) on the coil. If there's frost formation, the common cause is dirty cooling coil. Have it cleaned using an alkali base coil cleaner. If the coil is clean, then the problem is the fan motor. It might be turning slow due to copper loss. Have it replaced.
May 28, 2009 | LG Heating & Cooling
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
