Question about Gateway GM5084 PC Desktop
I added a new video card and the monitor wont come on
  • Gateway Master
  • 5,660 Answers
1) Did you plug the monitor into the graphics card?
(Hey, happens! Sometimes in our zealousness to see what that baby will do, we mess up a little)
2) Did you install the Drivers? First?
These will be on the installation disk that comes with the graphics card.
Recommend installing the software from the disk FIRST, then turn the computer off, unplug from power, install the graphics card.
3) Does the graphics card require additional power?
Some graphics cards will not receive enough power, from the graphics expansion slot they are inserted into.
[Gateway GM5084 uses a PCI Express x16 slot, for best graphics.
http://support.gateway.com/s/PC/R/1009054/1009054nv.shtml
(Left-click on Specifications]
Some powerful graphics cards require additional power cables from the Power Supply.
Post in a Comment.
Posted on Sep 29, 2010
Computer starts but moniter stays in sleep mode .. moniter works on different comp .. will adding a vid card to my comp fix this problem ??
Actually, Yes. It seems like you have answered your own question... Especially considering the monitor works on another computer.
Do you have another monitor to test on this computer?
Although another consideration could be if you recently installed or downloaded a program which may have changed your video output range to a setting your video monitor wont handle. If this is the case and you can start the computer in safe mode, this will allow you to go into your properties settings and change it back. This way, a new vid card is not req.
Good Luck
Sep 14, 2012 | HP Compaq dx2300 Microtower - RT950UTABA...
System will not turn on
If you are certian the pc is powered on, check the video card and any new card that has been added to the pc. If you have a video card installed, remove all other cards and retry your boot. If you still have no video, replace the card. If the video connection is on the board and you and have added a new video card, use the "old" connection to open your operating system and configure the video setting to use the new card and change connection.
Good Luck,
C2Solutions
Jan 02, 2012 | HP Pavilion a350n PC Desktop
How do I disable onboard video for Acer M1641? There seems to be no option to do so in the bios and I cannot get a display on the new video card. Computer does post normal.
You say the computer posts normal--is the video card being recognized within Device Manager? Try installing by adding a new device, then everything should be fine. Also make sure that your monitor is plugged into the card :) . Try different connections to monitor if available.
Apr 12, 2010 | Acer Aspire M1641-U1521A PC Desktop
My screen wont show anything
The issue might be due to malfunction on teh LCD monitor or internal malfunction, to confirm the same connect the notebook to external monitor and check for the issue
Mar 28, 2010 | Computers & Internet
Video reader knocked loose, moniter won't work.
You are referring to the Video Card - it is the card that the monitor connects to which could also be integrated depending on model. There should be beeps indicating if the card is actually loose. There is also a possibility that there is an issue with the new memory. Was the system not tested before you received it back? Have you tried it with the old memory? Service manuals are available on DELL's website.
Dec 13, 2008 | Dell Optiplex GX110 (2909T) Motherboard
Added a new video card, now my monitor stays in sleep mode
If the computer originally had integrated video, have you tried reconnecting the monitor to that output? Most system boards will automatically detect when you install a separate video card, but on some you need to disable the built-in video in the BIOS before the new card will work. Also, have you considered the chance you just got a lemon of a new card? It happens sometimes (it's happened to me!).
Nov 18, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Monitor problem
Hello soltaino, your board (K7VT2), did not come with a video card. (New). If you have a video card in your PC it was added. I'll need to know the name of the card to advise you regarding a cable to connect to the monitor. My guess is it's like the pictures listed below.
The Asrock does have an AGP 4x video slot. If your board has a video card installed it's connector would connect to a standard VGA connector at both the monitor & at the video card.
Whick looks like this.
The picture above shows a female VGA port, (like on a monitor).
b9662ed.jpg See the bue cable. That's a standard SVGA cable connector.
If you can not connect to the PC you need a new video card, not a new monitor. http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3667003&CatId=876
Suggest this card. It has both VGA & DVI connectores.
Best Regards!
Mike
Apr 01, 2008 | Asrock K7VT2 Motherboard
Computer won't come on
Does this computer have on board video? You mention that you added a new video card. Did you remove an old video card?
Do you see anything at all on the monitor at anytime while booting?
If it has onboard video have you checked the BIOS to insure that it is enabled?
Nov 20, 2007 | E-Machines eMachines Desktop PC
Gateway GM5084 PC Desktop Logo
180 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
