Question about Refrigerators
Condensing fan wont work put on new one.old one ran slow now wont do anything
    Sergeant:
    Champion:
  • 351 Answers
Don't know what kind of refrigerators you have if it is a ge may be the computer
Posted on Sep 29, 2010
My GE fridge PSi23SGNA BS freezer defrosted.
Condenser fan should be about 1300 rpm, I believe!
Jun 13, 2012 | GE Refrigerators
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
Kenmore model 3639550610. Ice maker motor and freezer fan motor wont stop. Need to find wiring diagram.
If fridge repair because it is noisy, turning off and on, or running all the time, it could be a sign the condenser fan motor is going bad. Thankfully, this type of repair is not as complicated as some may think. You can check the condenser fan motor yourself and replace it if necessary.
Tools and Materials Needed:
* Multitester
* Screwdriver
* Needlenose pliers
Step 1 - Disconnect the Power
Turn off the power to the refrigerator to prevent electric shock.
Step 2 - Remove the Condenser Fan Motor
The condenser fan motor is located on the bottom of the fridge, most likely toward the back. Heat from inside the fridge is released into the air here. A panel will probably need to be removed to access the motor. Depending on the screw, a screwdriver or nut driver will be required to remove the panel. Find the condenser fan and motor. You can quickly check the fan's operation by seeing if anything is obstructing its rotation. Manually move the fan blades to see if they spin freely. If they do not, you may need to replace the fan. Continue removing the condenser fan motor by taking out the screws that affix it to the mounting bracket.
Step 3 - Test the Condenser Motor
Your condenser fan motor will most likely have 3 wires attached. Some models have just 2. Note which wires are connected from the fan to the motor. Use needle-nose pliers to remove the wire connectors from the motor. Be careful not to damage the wires. After the connectors are removed, use the multitester to check the resistance or passage of electrical current. Set your multitester to ohms.
If the condenser motor has 3 terminals, only the outside terminals need to be checked. The inside one is a ground terminal. Check the terminals by using the multitester probes, touching one probe to one terminal and the other probe to the other terminal. The reading should fall between 0 and infinity. If you reading falls on either 0 or infinity, then the condenser motor is bad and will need to be replaced.
Step 4 - Replacing the Condenser Motor
Condenser fan motors can be ordered from the refrigerator's manufacturer. Once you receive the new motor, check it with your multimeter the same way as the old motor. This will make sure the new motor is in working condition. Attach the wire connectors to the new motor in the identical locations as the old one. You can refer to the new motor's wiring diagram (most likely included with it) if assistance is needed. Now install the new motor under the fridge. Attach it to the mounting bracket using the same screws as before.
Step 5 - Testing the New Motor and Keeping it Efficient
With the new motor connected and attached, turn the power back on. The unit should operate correctly. If it does not come on, check the wiring. Dust and dirt can plug a condenser and affect the fan's ability to discharge heat. Cleaning them several times a year will help the fridge run efficiently.
Hope this help in solving.take care....
Sep 18, 2010 | Frigidaire FRS3R5EMB Side by Side...
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
Slow fan on Window Air conditioner Sears 106.73220
if the motor seems like its getting extremely hot it could possibly be seezing up. i would suggest taking your volate reading for the motor and check for proper voltage, also check you amp draw on the motor. the proper amp draw should be on the name plat of the motor. any below the proper amp draw, replace the motor.
Apr 23, 2009 | Heating & Cooling
Slow condenser and evaporator fans on SDL20KCSABS
Newer GE refrigerators use variable speed DC fan motors to improve energy efficiency. Fan speed is determined by the electronic control board. Your refrig is working as designed.
Please don't rate solution, as anything but a Fix-Ya lowers my overall score. Thanks.
Mar 03, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
The heater quit working and the panel wont light up on a 1992 Chevrolet pickup
check the "blower motor fuse" "heater fuse" and ac fuse and relay. these will be located under the dash on the drivers side usually mounted near the foot rest next to the door AND under the hood along the fender on the passenger side.
Jan 08, 2009 | Chevrolet 1500 Cars & Trucks
Fan motor slow on a/c
If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
  • Compressor
  • Condenser
  • Evaporator
  • OR
    This could the problem the with short circuit or defective component you need to check :
  • Compressor
  • Overload and/or relay
  • Thermostat (Open thermostat)
  • Burnt wiring
  • Bad selector switch
  • Capacitor
  • Good luck....
    Nov 11, 2008 | Heating & Cooling
    1996 LX - Condenser Fan Blows Fuse
    Check the cooling fan relay under the hood on passanger side.
    Aug 17, 2008 | 1997 Honda Civic
    Kenmore refrigerator
    hi fperry74,
    please look at the back bottom part of the refigerator , if you could see a small condenser fan there. it might not be running or running very slow. correct that problem then.
    that is why your panel is very hot because a condenser line passes thru that panel and if the fan is not running, then the temperature gets very hot.
    the efficiency of the fridge is also affected.
    i hope i was able to solve your problem.
    pls rate me.
    tnx
    drcool
    Jul 23, 2008 | Refrigerators
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
