Question about Whirlpool Duet GHW9150P Front Load Washer
How do i remove the control lock - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 29, 2010
My right side passenger door does not lock automatically anymore. Is there a fuse that operates this.
no all is related to one fuse you can remove the door internal controls and decore and remove center lock motor plug and test two connectors with multimeter with set on 12v and then lock un lock door and check the reading of the multimeter if it read signal then all plugs and wires from central lock control unit to the door central lock unit is okay it this cae you have to replace the door central lock unit with the same if no signal is readed while you lock unlock the door then you have to check central control unit and all wire plus out of it to the door plug
2- you can remove central control unit from driver door and test it in passenger door (usually the same unit ) if it works with lock unlock its then the replaced unit is faulty and needs to be replaced if it not work then check plugs wires from central lock unit (usually found inside driver door ) to the central lock unit in passenger door
3- check signal for said door fro the output of central door unit if no signal then it mean that faulty central lock control unit
Feb 23, 2015 | 2005 Honda Accord
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
How do you remove the control lock when "end of
To unlock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light goes Off.
To lock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light comes On.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door lock assembly
Toyota Corolla 1988-1997 Repair Guide Door Locks - REMOVAL & INSTALLATION
(see Figure 1)
  1. Disconnect the negative battery cable.
  2. Remove the door panel and watershield. Remove the service hole cover.
  3. Disconnect the door outside opening linkage. Remove the two mounting bolts and remove the door handle if in need of replacement.
Fig. 1: Power door lock control system component locations
  1. Disconnect the lock cylinder control linkage.
  2. Remove the lock knob and the child protector lock lever knob.
  3. Remove the lock assembly retaining screws and remove the door lock. If equipped with power locks, disconnect the electrical harness.
  4. To remove the lock cylinder, remove the lock cylinder retaining clip and pull the cylinder from the door.
To install:
  1. Coat all the door lock sliding surfaces with multi-purpose grease.
  2. Install the outside handle with the two retaining bolts, if removed.
  3. Install the door lock solenoid linkage to the door lock.
  4. Connect the link to the outside handle.
  5. Install the lock knob and the child protector lock lever knob.
  6. Install the door opening control link tighten the mounting bolts to 48 inch lbs. (5 Nm).
  7. Install the door lock cylinder control linkage.
  8. Install the door panel and watershield.
  9. Reconnect the negative battery cable.
Hope help with this; remember rated this post and thank you for using Fixya.
May 20, 2010 | 1991 Toyota Corolla
Hello i have a 2004 cavalier and it will not go into gear can you help me?
This Is Park Lock Cable Failure here is the Replacment Procedure
Park Lock Cable Replacement
Removal Procedure
  1. Remove the console.
  2. Remove the knee bolster.
  3. Loosen the lower steering column bracket bolts.
  4. Lower the steering column.
  5. Place the transmission shift lever in the PARK position. Important: Do not proceed to the next step with the key in any position other than the RUN position.
  6. Turn the ignition key to the RUN position.
  7. Insert a screwdriver blade into the slot provided in the ignition switch inhibitor.
  8. Depress the cable latch. Pull the control cable from the inhibitor.
  1. Push the cable connector lock button at the shifter base to the up position.
  2. Unsnap the cable from the park/lock lever pin.
  3. Depress the two cable latches. Remove the control cable latches from the automatic transmission control.
  4. Remove the control cable clips.
Installation Procedure
Important: When installing a new park/lock cable, keep the shipping cover gauge attached until you are instructed to detach it. The shipping cover gauge will aid in the proper positioning of the cable.
  1. Ensure that the cable lock button is in the up position. Place the shift lever in the PARK position.
  2. Snap the control cable connector into the automatic transmission control.
  3. Place the ignition key in the RUN position. Important: Do not insert the cable with the key in any position other than the RUN position.
  1. Snap the control cable into the inhibitor housing until the snap lock is seated.
  2. Remove the shipping cover gauge.
  3. Turn the key to the LOCK position.
  1. Snap the control cable end onto the shift park/lock lever pin.
  2. Push the cable connector hose forward in order to remove any slack.
  3. With no load applied to the connector nose, snap the cable connector lock button down. Important: Inspect for proper operation of the park/lock control cable before installing the steering column to the instrument panel.
  4. Raise and connect the steering column.
  5. Tighten the lower steering column bracket bolts.
  6. Install the knee bolster.
Apr 08, 2010 | 2004 Chevrolet Cavalier
As to me to stitch the second key from ignition (with immobilizer) in memory of my car (Honda CRV-2,4 EX 2002, made in UK) if nearby is not present diller from Honda.
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 8 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control
NOTE THIS IS FOR YEAR 99-02
Mar 02, 2010 | 2002 Honda CR-V
How to recode remote to vahicle
Programming
When
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control.
Jan 18, 2010 | 2003 Honda Civic
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
How do i get rid of parental control
If it's the remote control that's locked, you can remove the batteries for about 30min. This should erase whatever lock has been put in place. If the lock is on the cable box, then you can contact the cable provider, explain your situation and ask for the lock to be removed. Hope this answers your question. Best of luck.
Greg
May 28, 2009 | Westinghouse Televison & Video
Door Lock
remove spring around door seal ..roll seal back into door opening remove 2 screws on outer frame holding lock in place ..pull lock through opening remove wires reinstall in reverse..are you sure lock is broke if you hear a clicking noise when lock should be closing suspect loose connection on main control bd ..remove top control is gray box on rear rail..try wiggling connections toward center of control if lock energizes and works suspect control ..may be able to shim plug in place but sure fix would be new control
Aug 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
