Question about Kenmore Elite HE4 Electric Dryer
About half of the control panel cycle buttons do not function. For example, when you push the “normal” button nothing happens. Other cycle buttons that do not work are: delicate, casual, bulky bedding, heavy duty and touch up. When you push the “timed dry” and “express dry”, however, those do function and the dryer works fine. Also, a faint red light is now permanently “on” between the “more and less” button. Is failure imminent? Many thanks.
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks !!
Posted on Sep 29, 2010
Can not start a wash cycle
Hello. From the symptoms you describe, the problem might be a defective control panel. First, make sure the control lock is not enabled!! Look for a button that has a "key" symbol or the word "lock" underneath it. Touch and hold for 5 seconds until the lock is disabled. The part numbers for the different styles of the dishwasher for the control panel are:
BLACK--W10329522
WHITE--W10329521
BISQUE--W10329523
STAINLESS--W10329524
The touch control panels can become damaged from a variety of causes. Power surges(Have you had an outage in the last 3-4 weeks!?), defective components, moisture invasion, etc. are the most common culprits. If a button is "electrically stuck"(i.e. the computer thinks you're still pressing it), nothing else will work until the button is released. It is just like any other appliance with physical buttons(soft touch for example on a microwave or range). Now, if the dishwasher actually starts when you press the start button, then the problem lies with the main control board(part# W10352588)--remember--a stuck button will prevent any other action until it's released. The troubleshooting on this unit is relatively complicated--when diagnostic mode is entered, the clean light will flash a certain number of times for the first part of an error code(function code, then it will flash again a certain number for the second part, problem code,(ex. blink 6 times, wait, blink 1 time). There is an error code chart that has the meanings to the different sequences--(ex. a 6-1 is inlet water valve(function), and then "no water"(problem). You press the start button to advance to the next stored error code. Power off the unit to go back to normal mode. If you are hesitant about performing any of the troubleshooting, call for service! I hope this helps you!
Oct 17, 2015 | Maytag Dishwashers
Kenmore ultra wash dishwasher only half of the lights light up when pressed when press start nothing happens
Do you mean only half of the lights that you push stay on ? If I try to push in too many buttons at the same time, or the cycles I push don't function together, that some of them stay off because they aren't programmed to run at the same time. And the machine is set up to not allow you to expect it to do all the functions during the same cycle.
Jul 19, 2014 | Kenmore 665
I used to have to push the 'start' button several times to get it to start the wash cycle, now...nothing happens at all? any ideas?
Sounds like your control panel is going out on you. It is not communicating at 100% to the rest of the unit. Contact your manufacturer and one of their service companies.
Aug 22, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Miele g898 sci plus won't start (type HG01)
Button wont stay in - lights up but nothing happens. Machine three and a half years old.
Dec 23, 2008 | Miele Premier-Plus Built-in Dishwasher
Washer not working
Okay...try unplugging the washer for AT LEAST 30 minutes. This will often cure momentary glitches with the washer computer. After the washer has been reset, attempt the start a load and let me know if it functions normally. If it doesn't, let me know what the front panel display reads.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
