Question about Tools & Hardware - Others
I have a model N08SB-1 Framing nailer. It was nailing and stopped. I can press the nailer against theobject that I want to nail. When I press the trigger it does nothing. If I have to get it repaired by a dealer, I will need to know the nearest one. My zip code is 53005.
  • 2,100 Answers
I don't know what brand you have there, but most nail guns now days have rebuild kits that makes it a lot easier for you to fix it yourself than to send it off somewhere. I have all senco guns, and the kits are readily available. You just buy the kit and replace every o-ring in there and don't worry about which ones are good or bad. Your gun should be the same way. I would check where you bought the thing first, then try ebay, or call them up and tell them you need a kit. All the repair shops we had around here have closed up on account of this. Hope this helps.
Posted on Sep 29, 2010
How do I release the trigger lock on a brand new porter cable nail gun
Are you depressing the nose of the nail gun against the material to be nailed first? Without doing this, the trigger will not "unlock". You can read a pretty in-depth review of this nail gun at OnlineToolReviews com Porter Cable FR350A Full Round Head Framing... which might also help.
Jul 16, 2014 | Porter Cable FR350A Factory Reconditioned...
Ridgid r350rhd-round head framing nailer the nail is jammed in backwards behind the push rod. don't ask me how it is backwards
FYI The fact that you've managed to flip a nail in the nose can suggest a nail that's too short. Rule of thumb is that framing tools use from 50mm (2") up.
Sep 20, 2013 | Ridgid Full Round Head Framing Nailer...
Nailer drives nails too deep
n80 coil nailer is a very powerful nailer used for hard wood. If the driver is setting nails too deep, adjust safety foot to the lowest level. Install safety foot no-mar boot to lift the gun even higher. If still too deep, most likely the lower bumper inside the gun is worn-out or cracked. Easy test. Remove nails and connect air supply. With trigger depressed, push and hold the gun against work (I use an old rubber hose tightly coiled up). This will fire the gun but keep the driver down allowing you to examine the tip of the driver. The driver should extend out past the nose less than quarter inch. If the driver is extending too far, most likely bumper is worn out. If a large quantity of air is leaking out the nose of gun during the test, indication that lower bumper is cracked. Good luck.
Apr 06, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
How does the framing nailer work with a black button grey button
Dewalt has two triggers available for their framing nailer. The black trigger (390746-00) is a bump style trigger. While holding the trigger, you will be able to fire a nail by pressing nose against work. This trigger is preferred by most framers because it is much faster. Gray trigger will only allow one nail to be fired. Bumping will not work with the gray trigger. With trigger released, you must place the nose against work then pull trigger to fire. To fire next round, you must release trigger, pull gun off the work, again place nose against work then press trigger. Check dewalt web site for recall information. Some dewalt framers have been recalled for faulty trigger. Good luck with your projects.
Aug 11, 2011 | Dewalt Round Head Framing Nailer D51845
I bought a used Bostitch nail gun. Model/serial # N6408406208021. What parts do I change to go from a 1 1/2 inch nail (approx. #6) to a 3 inch nail (approx. #16)? Where do I get the parts?
I do not think that the n64 will take a 3" nail. N64 will most likely fit a 2 or 2 1/2 inch. To verify the length of nail open latch door and measure the width of the slot into the barrel. Take a look at the bostitch n80 series of nailers for more power and longer nail.
Dec 18, 2010 | Stanley Bostitch Coil Framing Nailer
Stanley coil roofing nailer not sinking 3 1/4
That model may not be designed for that length nail. Check with your local supplier.
Mar 10, 2010 | Stanley Bostitch Coil Framing Nailer
Exterior Galv. 6d cooler 2x .113 21 degree
This nailers are very inclusive , i have experience issues when i try other nails brands, and when i put DeWalt nails they work just fine. keep in mind that most nailers have a safety that when a couple of nails are in the magazine it wont shoot,
Apr 02, 2009 | Dewalt D51844 Framing Nailer
Problem accessing nails
Hi, No you can't. They are two different feeds. The F33 uses tape feed and the N79 uses stick feed. The N79 is a basic wood frame nailer that uses 3 to 3 1/4 sticks, while the F33 uses up to 2 1/2 paper feed. The stick nails are the most common for the older nailers and on the box look for Bostitch as the brand to fit, as the N79 was sold under that brand not Stanley. This should Fixya!
Mar 02, 2009 | Stanley F33PT Paper Tape Framing Nail
Tools & Hardware - Others Logo
24 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
