Question about Cycling
I am having trouble with my Hercules bicycle (made in England). I cannot find a way to raise the handle bars. I was wondering if they are raise-able. If they are how can I go about doing so?
    Genius:
  • 1,788 Answers
I would have it in to a professional bike shop, they can tell you if you have a long enough stem to do it, it has to be in the head tube at least 2 1/2" or it can snap. You would also be able to buy a new stem from them, if necessary.
Posted on Sep 29, 2010
How do you raise the handle bars on the bike?
If it is an older bike, you loosen the bolt at the top of the handle bar shaft until it is about 1/2 inch raised. Take a hammer and give it a swift bump and it should drop into the shaft. Hold the front tire between your legs and the handle bar should raise up. Re tighten once every thing is lined up. If the bike has front hand breakes these may need to be adjusted.
Aug 05, 2014 | Generic 16" Raskullz T-Rad Rex Boys Bike
you cant raise the handle bar but you can add spacers to increase the height.Wish we could be able to raise the handbar
Jul 06, 2014 | Genesis 26 Inch V2100 Dual-Suspension...
I need to raise the handle bar on diamondblack Odyssey DB78 mountain bike. It has a "cartridge system inside" stamped on the top post around the allen key. I loosened the alley key but...
Simply web search for "raise the handle bar" and you get lots of resources.
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Aug 07, 2011 | Diamondback Cycling
How do I raise the handle bars on my mongoose xr 200 21 speed bike
Your handle bar stem has a metric screw in the the neck of the bicycle. But, a word of caution, do not raise your handle bars more than the safety mark on the stem, it has to be inserted that much or it and it can snap in two and result in serious injury. Take it to a bike shop and they can either show you how or advise you on replacing the stem with a longer one. This is a very important part on your bike, do not take chances.
Apr 05, 2011 | Cycling
I have a Sirrus bicycle made by Specialized. Is there a way to raise the handlebars?
There are a number of ways to raise the handlebar, depends on how old your Sirrus is.
The most common is too replace the stem with one that has a higher rise to it. Take your bike into your local bike shop and have them take a look at your set-up and they can offer specific options depending on how high you want to raise the bars.
NOTE: Depending how high you raise your handlebars you may need to replace your cables and housing to your controls. Also you may have handling issues if you raise the bars too high. If you are raising your bars because your uncomfortable or having pains in the neck or back you should consider getting a bike fitting to make sure you are properly mated to your bicycle.
Mar 20, 2011 | Cycling
Can I raise up the handle bars on my 26" Ladies'
No, but a bike shop can assist you in selecting and fitting a stem with a higher rise.
Feb 24, 2011 | Columbia Sportswear Columbia 26" Ladies...
Schwinn Impact MOS.....can the handle bars be raised? If so, do you loosen the small star nut on top, or the large nut at the base of the handle bars?
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
May 22, 2010 | Cycling
Need to raise the handle bar on my 2007 Marin Argenta road bike.
The stem for the marin is fixed so you'd have to replace it with one that is higher if you wanted to raise the elevation of your handle bars. You can pivot the handle bars for your preferred angle of comfort though. Loosen the 4 screws on the top of the stem and then you can adjust the handle bars to the correct angle that is best for you.
Jan 09, 2010 | Cycling
Handle bars adjustment - want to raise the handle bars
You will have to go to a bicycle repair shop and ask for a handle bar stem extender. They come in various lengths.
Nov 29, 2009 | Jeep Wrangler X Mountain Bike
Cycling Logo
42 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
