Question about Fuji Photography
I turned my camera and it says turn off the camera and turn on again! It's not working. What do I do?
    Brigadier General:
  • 3,006 Answers
Your camera almost certainly has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Fuji service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 29, 2010
Fuji HS20EXR wont turn on after turning off
A defective rechargeable battery caused this on my camera, not sure about the blue haze though. Make sure battery is good or use fresh alkalines.
Mar 24, 2014 | FUJIFILM HS20 EXR Digital Camera
Not working always show "turn thepower off and on
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Aug 01, 2011 | Sony Cybershot DSCW310 Digital Camera
My m1093 kodak camera won't turn on, it turns on briefly and then turns right back off again. i have tried charging it but nothing works
try taking out the battery and memory card, then put back in the battery, and try turning on again
then if that works put in the memory card and turn on
or try connecting to ur computer and transferring the pictures and then disconnect and try turning on again
Aug 04, 2010 | Kodak EasyShare M1093 IS Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Please turn camera off & then on again
off the camera again and try to open the menu and try to reset it .if the problem persist send it to the survice center
Feb 03, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
"turn off and on again"
a few weeks ago i dropped my camera in the sea and i thought, ****. i was in the same boat, so i opened the shutter myself and turned on the camera and it works and takes pictures but the shutter wont close again so if you can make sure you have no dirt in your lense and you can manually open the shutter yourself it may work and if it stops turning on all together keep charging it and once it goes green turn the switch off and on again until it always turns green then it should work again.
Jun 22, 2008 | Samsung NV3 Digital Camera
When i turn on my camera it says Turn the power off and on again
Hey, my camera the dsc- w80 did the same thing. When I turned it on, the lens opened 3-4 times and then it said "turn the power off and on again".
When the lens opened an closed, I pulled on it with my fingers and twisted it. I kept doing that: Turned the camera on and off, kept pulling and twisting the lens and now my camera works again!
May 15, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Photography Logo
93 people viewed this question
Top Fuji Photography Experts
TC CAMERA REPAIR.Com...
David Payne
David Payne
Are you a Fuji Photography Expert? Answer questions, earn points and help others
