Question about Acer AL1916W 19" LCD Monitor
My moniter is saying no signal. just unplugged everything and plugged it back in
  • 11,361 Answers
Try it with another PC, check all the pins on the cable to make sure it is not the video card paroblem. Post back what you find before taking it apart.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 29, 2010
3 Suggested Answers
chrisgoforth
  • 55 Answers
SOURCE: moniter is black but has power
right click your desktop (when you can see it) and go to properties. Click the screen saver tab, CLick power button change the setting next to turn off monitor to Never. It sounds like the monitor is going into a sleep mode and not coming back out of it. Some monitors have this issue.
Posted on Dec 19, 2008
  • 188 Answers
SOURCE: Hanspree monitor says,''No signal input check video cable''
ask the shop for a replacement cable. it could be broken.
Posted on Mar 26, 2009
I WANT TO USE MY DESKTOP TO PLAY FILMS ON MY TV . DONE THE CONNECTIONS AND GOT THE RIGHT SCREEN WHEN THE COMPUTER STARTED UP THEN IT WENT BLANK SO I CHANGED THE RESERLUTIONS ON A MONITER SCREEN THEN...
What you should try at this point is shut everything down, Unplug your desktop, hook it back up to tour moniter and boot. If you now get a picture, go to your device manger and click on display adaptors. If you have more than one selection. choose your monitor. Let me know if this works.
Mar 11, 2011 | Computers & Internet
Hi! and Happy New Year! Hoping you can help me with a problem with my moniter. When it starts up it says Flatron f engine for the model type. Problem: for about 2 weeks now, at start up the moniter...
I suspect your computers power setting are turning off the monitor and not reactivating it (waking up) I would suggest attempting to change your power setting to never turn off monitor and see if that fixes the problem.
Please let me know if that works if not I can go over a few trouble shooting steps with you.
Thanks
Dustin
Jan 03, 2011 | LG Computers & Internet
My moniter says no signsl but the windows is working and i checked the moniter to my laptop and it works fine
Believe it or not but theirs an order in witch you should connect up a compute,r but first make sure that there is only 1 VGA port ie (monitor socket) on the back of it. But if theirs 2 then try the other one.
Other than that try this:
Unplug EVERYTHING! even the power leads from the back of the monitor & pc.
1.Press the power button on pc & monitor to flash out any power left in them.
2.plug in & tighten the VGA cable to the pc then to the monitor if required.
3.plug in all other peripherals ie USB / MOUSE / KEYBOARD etc...
4.plug in the power supply to the monitor then the pc.
4.Switch on the power supply to the monitor first then the pc.
5.Switch on the monitor by it's power button then the pc right after it.
Jul 02, 2010 | Acer X193W LCD Monitor
My computer says no signal
Check you rmnitor data cable from CPU its not connected
Oct 05, 2009 | E-Machines eMachines W2686 PC Desktop
I have a new video card and new monitor my computer still reads no signal
your video card is probly too new for your moniter so it cant process the commands the motherboard is sending. get a new moniter
Sep 25, 2009 | Computers & Internet
Moniter says no signal
You may need to replace the moniter cord or check the video card on the computer.
May 31, 2009 | Acer Aspire™ T180 PC Desktop
Mar 26, 2009 | Computers & Internet
No signal on advent monitor
Hi
First thing, change the cable and use a digital cable, Power everything off, disconnect the power from the moniter and the pc, leave it for 2-5min and then connect them back again.
Let me know what happens
Mar 23, 2009 | Advent 4211c Notebook
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
