Question about Whirlpool Refrigerators
Replace and install Nozzle and Tube Kit on Whirlpool Refrigerator, Model No. ED25DQXBW00 .
2 Suggested Answers
aasc
  • 1606 Answers
SOURCE: Whirlpool model #GD25DIXH02. The front water
Remove the top free door hinge cover and disconnect the plug there . This removes all power to the door . Remove the grill inside the dispensor , and remove the 2 screws at the bottom , holding the dispensor cover on . Lift the cover to remove , and disconnect the receptical , freeing the front . Next , remove the 4 screws holding the white dispensor switch mount , and slide out . Remove the screw holding the water fitting assembly .
Remove the bottom refrig kick plate . Follow the tube about 6 " to a connector , and disconnect the connector . The plastic compression nut , slips off the tubing after disconnecting .
Pull the dispensor tube , up thru the door from the top . Using the new tube with spout , pt number 4388152 . Insert the new tube into the hole from the top , and feed down , thru the door . Re-assemble in reverse .
Posted on Oct 27, 2009
Ice forming under the freezer drawer & on drain tube water pooling in floor Cleared drain tube, what else?
Whirlpool corp., whom made this unit, had a bad design for the defrost drain tube by the compressor. Order part W10619951 and install. This is a kit to change out the current drain tube to a better one. You still have to defrost the frozen defrost drain tube but this will fix it for good.
Aug 01, 2015 | Maytag MFI2269VEM Monochromatic Stainless...
I have the model ED5VHEXVQ Whirlpool side by side refrigerator and the ice dispenser flapper will not close all the way after dispensing ice which causes the build up of ice crystals inside the door. This...
Hello, Thank You for using FixYa. I will be helping you today.Alot of times the plastic clip breaks that holds the pin and spring for the flapper door the only way to fix it is install part 8201756 and it comes with directions.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
GS5SHAXLBo1 whirlpool start relay is different on mine , i called whirlpool they told me mine was a producation start relay and now they a a replace kit wiring is different , do you know anything about...
they told you correct . i looked your model and the org # subs to the kit 8201786 / i use these kits for many brands and what is in the kit is 2 start relays and 2 over loads and instructions an diag .. it's not a hard job . when removing the old relay read the # and see if it matches one of the new one and if so thats the one to use . if neither one matches then the brand of compressor will tell you which one to use . just read ite destructions before installing relay kit and if you remove any wires make a diag of where the were so you can reinstall them correctly.. rule # 1 its hard to back up without a road .. mm hope this helped mm feed back please ..
Dec 11, 2010 | Whirlpool GS5SHAXN Side by Side...
How do i install a lp conversion kit for a dlg2051w
It's really quite easy, I did my Maytag in about 30 minutes, the kit will have instructions.
Usually there is a regulator bypass piece and a nozzle change, find the correct parts in the bag and follow the gas line from the back to the regulator, replace the regulator piece with the bypass, then move to the end of the tube on the other side of the regulator, on the end will be the nozzle, just u]screw the old and screw in the new, leak check and you are done.
Jun 15, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Have a top freezer MOD # ET4WSKXSQ01.. SER#VSW3914735
The ice maker kit you need , is IM1 kit . This comes with an icemaker , tube , water valve and everything needed to install . Instructions are included .
May 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
I need to install a new fitting (part # 2196157). That is the fill tube on the ice maker on our whirlpool refrigerator (model number ed2fhgxkt00) The water line is already detached since the threaded part...
Yes that s it. You may have to tug a little to get the old one out as sometimes the foam will try to hold them in a little tight.
One thing to check before you connect your water line. Take a look at the end of the water line for a minute make sure that no water is going to drip out of it. If it does you may as well replace the valve because that is going to plug the tube with ice and possibly damage the ice maker.
Reconnect your water line and flip the ice maker on and the water should start to flow shortly. That s it.
Thanks for asking.
Nov 20, 2009 | Whirlpool ED2FHGX Side by Side...
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool refrigerator side x side doors make a popping noise if opened past halfway... model GS5SHAXNL00
The door closing cams were worn on both doors. I had to buy a cam kit that cost about $10.00 and had the parts for both doors in it, take off the doors, and replace the cams. Before taking off the door that has an ice and water dispenser, I had to turn off the water to the fridge, take off the front grill, and disconnect the water tube that goes into the door (as the tube is threaded through the door cam). After replacing the door closing cams and reassembling, there is no longer a popping sound.
Jun 10, 2009 | Refrigerators
Refrigerators Logo
82 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
