Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
Remote control device model # 47-1001 no good was there a recall on this item
What code for d tv using dish remote?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Dish remote control code list, and setup procedure is given, either in one among the above site; I do recall that I've seen it.
Jul 25, 2014 | Durabrand Televison & Video
Tip
Service menu codes panasonic
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save.
PA25UP / PD25UP / PX25UP :
* Using the remote control:
* Press the {MENU} button.
* Set "Antenna A" to "Cable".
* Select "Timer" menu and set sleep timer to 30 min.
* Press {OK} twice to exit menus.
* Tune to channel 124.
* Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
?ƒ?¢?¢?€??¬?¢?'¬? Red "CHK" for Serviceman ?ƒ?¢?¢?€??¬?¢?'¬? Yellow "CHK" for Aging ?ƒ?¢?¢?€??¬?¢?'¬?
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
LCDs / CRTs / RPTVs :
* Hold down the {VOL -} button ON THE TV.
Model PT45LC12:
1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
3. Use Channel Dn button to select Digital and press the Action button.
PROJECTORS :
* Go to "Options" menu.
* Highlight "OSD".
* Then press and hold the {ENTER} button,
until the Service Menu is displayed.
* Press the {MENU} button to exit.
on Apr 29, 2015 | Panasonic Televison & Video
Why won't MX 900 turn on even after putting in new batteries
The obvious question here is: are the batteries installed the correct way? Here is a web page to download the operator manual:
http://www.universalremote.com/pdf/MX-900OwnerManual.pdf
Also; are your batteries good? are they making good contact? Has the remote been damaged by leaking batteries? Inspect and test.
Do you have the original remote controls for the devices you are trying to control? If so... do they work? Remember... they will need batteries too!
Are there manual switches on the device you want to control? Do they work? Can you turn it on and off?
We are moving through a process to identify which items work, which are good and which are faulty.
Jul 19, 2014 | Universal MX-900 Remote Control
Have a jumbo remote with no code search button also only programs 3 devices tv'vcr&dvd
I had the same problem Johny. Everybody wants to tell you how to program the one with the CODE SEARCH button. Here\'s how to do the one without. Press and hold the item button you wish to program (TV, DVD etc anyone of them can be used for anything) until the LED lights and stays on. Turn the item on manually and point the remote at it and push the power button. When the gadget turns itself off, immediately press the item button again. You can recall the code by pushing the item button until the light turns on again and then press DISP. Now push the number buttons (random is OK). As you hit the correct number of the code, the LED will flash until the four digit code is entered then the LED will go off. You may wish to try for more codes as some function better than others that just simply "work".
Jul 02, 2011 | Innovage Jumbo Remote Control
Ordered a new Toshiba SE-R0177 remote for TV model #15DLV16. New batteries installed. How do I set it up? It did not come with a manual and the original manual no longer exists. Can't find one online...
. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
Mar 17, 2011 | Toshiba Se-r0177 Remote Control
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
The modes are:
etc.
clock.
service menu.
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
I need the codes for a Phillips TV/VCR combo and procedure to program my universal remote.
  • Collect together the manuals or model numbers of all the items you want the universal remote to control. You will need to know manufacturer's name and the model number of the product. You will also need the owner's manual for the Universal Remote
  • Find the codes for the devices that you want to operate. The codes are located in the Owner's manual for your remote. Be sure to match the codes up with the exact model number of the item that you are trying to operate. Each item must be set up and programmed into the remote individually.
  • Program the devices by this guideline for the process. These will be different with each model of remote chosen but this is the general procedure, so you know what to expect. To program a TV into the remote perform the following: Press and hold the code button on the remote until it stops flashing. Press and release the Code button and select the device this is for, and enter the three digit code for the manufacturer and model number of your device. With the device on, press the Channel UP key and see if the channel changes. You are done with that device if the channel changes. Repeat the process for each of the other devices.
  • Nov 07, 2010 | Philips SRU2103S-27 Remote Control
    Craftman 1/2 garage door. Model 13953879. RF intereference issue
    Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
    Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
    Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
    The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
    Multiple garage doors:
    If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
    Power Down test:
    To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
    If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
    Apr 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Model 139.53930DM Remotes very eratic, will not
    I am going to assume you have short range with your remotes and give you some stuff to check.
    LIMITED RANGE
    If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
    Power Down test:
    Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
    TV one side slight blurr
    hello, here some help with this
    hope this help below are adjustments
    and values
    How to enter into Service Mode
    While pressing [VOLUME ( - )] button of the main unit, press [RECALL] button of the remote control three times within 2
    seconds.
    10.1.1. Key command
    "1" button...Main items Selection in forward direction
    "2" button...Main items Selection in reverse direction
    "3" button...Sub items Selection in forward direction
    "4" button...Sub items Selection in reverse direction
    "VOL" button...Value of sub items change in forward direction ( + ), in reverse direction
    Value is shown as a hexadecimal number.
     ·Preset value differs depending on models.
     ·After entering the adjustment mode, take note of the value in each item before starting adjustment.
    Main item Sub item Sample Data Remark
    ADJUST CONTRAST 000
    COLOR 3F
    TINT 03
    SUB-BRT 800
    WB-ADJ R-CUT 80
    G-CUT 80
    B-CUT 80
    R-DRV E6
    G-DRV F0
    B-DRV FC
    ALL-CUT 80
    ALL-DRV FC
    OPTION BOOT ROM Factory Preset
    STBY-SET 00
    Emergency OFF
    CLK MODE 00
    CLOCK 000
    AGING RGBW
    COUNT
    ALL WHITE
    ALL RED
    ALL GREEN
    ALL BLUE
    ON/OFF
    RAMP WHITE
    RAMP RED
    RAMP GREEN
    RAMP BLUE
    1% WINDOW
    COLOR BAR
    A-ZONE B-ZONE/4 TRIO
    SCROLL
    WHITE FLAME
    RM-SET CODE A Fixed
    SRV-TOOL - See next
    10.1.3. How to exit
    Switch off the power with the [POWER] button on the main unit or the [POWER] button on the remote control
    good luck hope tis help.
    Jan 18, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
    Heating & Cooling Logo
    541 people viewed this question
    Top ACE Heating & Cooling Experts
    Andrew Taylor
    Andrew Taylor
    Tim Whalen
    Mack Baxter
    Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
