Question about Viking VGSC306-4B Gas Kitchen Range
Can you clean off the ignitor and reinstall? Or if it goes bad, it just goes bad. Seems to be a lot of build up on ignitor. Can I sand it off and reinstall, or do I need a new one?
    Sergeant:
    Champion:
  • 351 Answers
No get a new one
Posted on Sep 29, 2010
When my stove is running it seems like the gas builds up and there is a tiny explosion. is that the ignitor?
Yup...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 07, 2011 | General Electric Kitchen Ranges
When i power on it says lens error and shuts off whats wrong
There may be something jamming the lens when it attempts to extend and open up when powered on. A lot of times dust build up or dirt/sand may cause this . Unfortunately if the build up is too bad, the camera may be damaged beyond repair. You check with your local camera store to see if they clean them, or also check the company's website for customer service and support as well.
Feb 19, 2011 | Cameras
The Goodman Heater was installed in 2004. Thermostat set at 75F, the fan that blows CO2 out was on for about 1 minute, then I could hear the sound of the gas blowing into the furnace, but the ignitor...
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 30, 2010 | Goodman GMS80903BNA Heater
Heater keeps turning on & off but no heat
What type of heater are we talking about? if its the home furnance, it sounds like the ignitor is coming on and shutting back down, the heat comes on ignite and the blower comes on like normal, then after a few minutes it will shut down, you will have to remove the ignitor, clean it with a little piece of sand paper to remove the carbon build-up, replace the ignitor and turn the furnance back on, this should correct the problem.
Dec 14, 2009 | Heating & Cooling
The unit will turn on and run fine for a few minutes then shut off. It won't immediately turn back on, almost as if it hans to cool back down first. Any ideas i have a lennox furnace
The ignitor will light, the blower will start up and run for a few minutes and then the system will shut down, and the blower will continue to run and cool down. The ignitor is not working properly, the ignitor has carbon build-up and need to be removed, cleaned all the black carbon from the ignitor with a little piece of sand paper and replaced, turn the heat back on and this should correct the problem.
Dec 12, 2009 | Heating & Cooling
Heater ignitor will not turn on, little black box on circute board is ticking twice without any ignition?
You may have a bad sensor lead. Check to see if it groulded anywhere along the wire. Clean ignitor probe with some sand paper.Rus
Oct 29, 2009 | Goodman GDS80904BNA Open Flame Heater
Seems to be clogged and will not drain a bath mat's bottom surrface completely crumbled into a sand like mixture
Your strainer's likely plugged with the "sand". Locate your dtrainer, situated between the drum and pump, and connected to the drum with a rubber hose. Clean and reinstall it. Get all of the sand out, and remove any that you can see laying in the pump cavity, etc. Run an empty load to flush the machine. This may have to also be done a second time if there is a lot of residue.
--W/D--
Aug 18, 2009 | Fisher and Paykel IWL12 Top Load Washer
Heater lights fan comes on flame goes out
There is a flame sensor located in the same area as the ignitor (usually on the other end of the burners). remove the flame sensor with the power off. Then use steel wool or light sand paper to clean the silverish end. Reinstall the sensor and ToDA you are done! Best of Luck!
Jan 29, 2009 | Goodman GDS80904BNA Open Flame Heater
Jenn Air lp grill won't light with the ignitor button
I just finished cleaning our starter on our jenn air. Over time, corrosion, rust and battery acid builds up on both the coils on the lid (positive side) as well as in the battery chamber and negative tip inside the chamber. I used sand paper and sanded the coils in the cap and the chamber. The coils need direct connection to the battery to create the charge. There are no instructions on this that I was able to find. I figured it out after about 3 hours of fussing with it. It worked immediately once I placed the battery back in. You may also need to clean the electrode tips near the burner. I used a q-tip. Hope this helps.
Jul 23, 2008 | Grilling
JGBP28 Self cleaning works but oven does not
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Nov 04, 2007 | GE JGBP28 Gas Kitchen Range
Viking VGSC306-4B Gas Kitchen Range Logo
61 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
