HP CM1015 , has scanner error 14 . Printer works fine . Any idea ? TIA Henrique
  • hvianna Sep 29, 2010
    It did not help me .
    There must be a meaning of the scan error 14 .
    I know it is called also ERR_LED_TEST .
    Please help me more .
  • 493 Answers
The recommended action for these kind of error messages:
1. To replace the scanner sub-assembly (in this case the led).
2. To perform the post-repair tests #1 and #2 which are explained in the service manual of the printer. You can download the service manual from this link which I uploaded for you and search the page #73 (#63 on the page).
Hope this helps.
Posted on Sep 30, 2010
  • 4,737 Answers
This error code indicates the the scanning unit has a faulty. In most cases, it's the Scanner Motor faulty, maybe it's dead or it not running at an appropriate RPM (revolution per minute). From users' end, we can only try the following steps:
Remove the drum and all the cartridges, Turn off the machine, now remove the fuser after disconnect the power cord and the usb cable. Clean whatever you think is necessary like paper passage with a blower or air can, clean the toner/drum chips using a cotton bud dampen with alcohol or spirit or acetone. While they are left to dry, press the power button several times so that any static voltage might be discharged.
Now reinstall the fuser unit, reconnect the cables, and power on the machine while you keep tapping the cancel button. Reinstall the drum and cartridges and then check whether this helps or not.
If this doesn't help, then you need to call hp or call an experience hp technician to inspect the unit. Likely, some parts need to be replaced.
This is all what I can help you from my side since I can't inspect the Machine myself physically. I wish you good luck.
Thanks for using FixYa.
Posted on Sep 29, 2010
Getting 79 ERROR on CM1015 printer. Printer shows error then powers off and repeats.
Error 79 indicates a internal memory error, specifically, it can indicate the internal memory is full. You can try printing the printer's test page, it shouldn't fill the memory and it should print. Here's a link to the official HP error 79 trouble shooting instructions for the CM1015.
HP Color LaserJet CM1015 MFP and CM1017 MFP Series Printers Control Panel...
Jan 25, 2015 | HP LaserJet CM1015 All-In-One Printer
Error 51.23 after paper jam
**Yellow laser scanner error, replace scanner assem..For tech guys: Remove scanner assembly, remove cover,check for yellow scanner motor rotation. if its hard or struck, gently remove engine motor,lubricate the shaft fix it back & verify rotation, how ever entire unit opened clean all reflector glasses with ear buds gently, fix the unit back properly.(out of four screws, factory wont fit one or two screws for alignment match, same way fix the screws, don't inter change). check for print if its rectified. process end..or else replace scanner assm..
Dec 21, 2011 | HP LaserJet CM1015 All-In-One Printer
Hp clj cm1015 for vista 32 bit
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
Feb 03, 2011 | HP Color LaserJet CM1015 Printer
ERROR 14 EN HP CM 1015
Scanner error. You need to replace the scanner assembly, the thing at the very top of the printer. you will need a tech if you arn't one.
Hope you have a warranty.
The part number is CB394-67901
Jan 14, 2011 | HP LaserJet CM1015 All-In-One Printer
I have an HP Laserjet CM1015 Priner/scanner and an HP pavillion running Windows Vista. When I try to scan anything it says an error occured communicating with scanning device and check it is connected...
I had this too on my Vista. I re-installed the original software that came with the printer and the scanner then worked OK. My problem was always triggered when HP automatically downloaded 'updated' software, so I would disable the update feature as it only causes problems!!
Hope this works for you.
CK39
Dec 17, 2010 | HP Color LaserJet CM1015 Printer
I'm using an HP 1015 MFP and the magenta does not print (well, may print faint). I've replaced with new cartridge to no avail. Any ideas?
Bad news. The problem is the scanner needs to be cleaned. It will cost about 85.00 or so. It's a lot of disassembly to get the scanner out to clean it. Any more questions fell free to call. 818-888-0006 Steven
Feb 21, 2010 | HP LaserJet CM1015 All-In-One Printer
HP CM1015 copy/scan problem
DO THIS CHECK WHERE THE CATRIDGES IS IN ORDER.OR IF IT IS LEAKING
Jan 17, 2008 | HP LaserJet CM1015 All-In-One Printer
The CM1015 scanner does not work with new Leopard OS
Same problem here. HP tech support no help. I've been transferred like 8x and been on hold for over a 1.5 hours and i'm still being transferred to another department!
Oct 31, 2007 | HP LaserJet CM1015 All-In-One Printer
63 people viewed this question
jasbo
jasbo
