Question about Kitchen Appliances - Others
I bought an older Gensaco Mach 2.57 Elfa 8 and it has no instruction manual with it. I really need to know how to get into the tank, but an entire owners manual would be nice.
I have the non-automatic version of the Mach 2.57 the SA. I am looking for the same information. I have rebuilt much of the unit and have it working to a fashion. These are quite old machines now. the former owner of the company is in prison for attempting to murder his pregnant girlfriend.
The original company in Italy that made most of the parts for this machine would be the best bet for any further information. I am in the process of researching that at this time.
RH
Posted on Sep 14, 2013
Not really a problem, more of an inquiry. I have recently purchased a kings post ACU but without an instruction manual. Could you tell me if you have to permanently have a drainage hose on or is there a...
Not much of an answer ... more of just a thought ... I am not familiar with this brand.
There must be some way to get rid of the condensate because there will be condensate. I presume you have made a cursory examination for a tank and found none but evidently you found some plumbing type outlet. I suggest you look again for a tank. If there is really no tank, then you will have to arrange for the condensate disposal. You don't say what kind of plumbing connection there is ... I would be inclined to modify that connection to accept a garden hose and lead it to a drain. Problem here is you probably want to use this unit in your house where all the drains are UP. In the basement, no problem ... lead it to the sump or the floor drain. If it has to go up, you will have to rig a pump through a smaller hose ... a pump like a small fountain pump using a 1/4 or 3/8 plastic hose.
If you bought this unit at a store - you could go back and ask for a manual or instruction. If you bought it second hand ... you will have to sait until someone with "Kings Post" experience.
I have sad several units similar to yours though different makes. There must be some accomodation for condensate.
Keep looking for a tank .........
Good luck ... thanks for your inquiry.
Jun 25, 2011 | King Post AC-9000RH Air Conditioner
Hi There, we've bought a SX62 Baumr-AG chain saw. On page 8 of the instruction manual - Point 3: "Install the attached spike to the power unit" - there is no diagram that refers to this...
I have just bought one and the manual is hopeless but finally I figured it out. If you have installed the chain and guide you will need to remove them, then with the saw lying on the side and chain cover off you will see two holes on opposite side of the oil tank/engine casing
Nov 05, 2010 | Garden
We have an brand new Cimmaron two piece. It has only been in for a week. Twice the tank emptied compeltely on a flush and did not refill. We have to fill the tank manually to get things working. Once we do...
Sounds like the fill valve may have something stuck in the part that makes the water shut off. This can cause it not to refill as it doesn't let the inner mechanism work as it should. If your home is a little older and depending on the piping in the home it is possible in the change that some debris passed through the system when the water was turned on. Another possible issue is that when attaching the water to the tank the fill valve was turned to where the float for the mechanism is jammed against the side of the tank and is not moving freely with the water. If this is the case then the entire body of the fill valve will need to be twisted so the float can move freely. Aside from these things, you may want to simply replace the fill valve to avoid any further complications or issues. Don't worry, anyone can do it and is only about $10 to do. I recommend Fluidmaster brand, they come with really good instructions.
Aug 18, 2010 | Kohler Cimarron Comfort Height elongated...
Robert Penny robertdrum55@gmail.com Where can i buy Akai EWI4000s and EWI-USB in Australia
This is the site:http://www.elfa.com.au/products/product+details?pid=71959 Electric Factory I88 Plenty Road Preston, Victoria, Australia Tel: (613) 947-41000 www.elfa.com.au List price for the EWI usb was$999.00. If this helped please rate me.
Apr 15, 2010 | Akai Ewi4000s Electronic Wind Instrument
Toshiba satellite laptop will not install Windows XP, Windows 7 or Linux Mint. Have run memory test.. RAM is fine. Please help me. - donman92.
What system is on it now? 98? Did you try an XP upgrade. If she is an older mach. I would not go beyond xp. Have you tryed Ubuntu? Does it have a good Hard drive? Get a Linux live CD image from the net and burn that on to a CD see if the HD is good. Maybe the HD shes too small. I do not have any info on your mach.
Oct 17, 2009 | Toshiba Satellite A105 Notebook
Fuel injectors i think..
Go to a autozone or similar auto parts store and tell them what u have told me here. They will have a gas tank additive which will clean the injectors merely by pouring it into the gas tank and driving for a couple of miles. good luck
Mar 19, 2009 | 2004 Nissan Titan
Coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Electrical Problem
I really donno what that is, but when u say element my guess is a heater of some kind, if so there will be thermostat some where or a thermal overload. Most of the time u could reset it.
Sep 11, 2007 | Gensaco Mach 2.57-sa
Kitchen Appliances - Others Logo
95 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
