Question about Whirlpool Dishwashers
I have a Whirlpool dishwasher model number DU1055XTPQ4 that is not cleaning the dishes. When the dishwasher is working, the bottem arm is turning and water comes out the holes. The middle arm has some water coming out, but does not turn. The top arm does nothing. It appears I have a pressure problem. I took out all the arms and cleaned them, along with the plastic tube that feeds them water. They had some build up on them but not much. I have the same result as before. I took off the water hose going to the dishwasher and turned on the water to see the pressure coming out, and it was very good. It filled a half gallon container in a few seconds. There appears to be a problem in the dishwasher. Any suggestions?
catriver
  • 878 Answers
SOURCE: The arms of my dish washer won't move
First thing you want to do is make sure the spray arms themselves are o.k. The ports are not clogged and there are no cracks. Once you are satisfied this is not the problem, check the seal ring on between the lower spray arm and the spray arm support on the pump. See if it is out of position or damaged. Make sure the water level is not too low, should just come in contact with the bottom of the heating element. Next check your filters, look for garbage, plastics, anything that would clog it. Last would be the pump itself. Ron
Posted on Apr 18, 2006
  • 1462 Answers
SOURCE: Dishwasher not getting water into spray arm, so no clean dishes
two possibilities: open door when in use. check if water is coming out of the spray arms. if it is and at a good rate, then the problem may be the spray arm jets blocked. the spray arms are only rotated by water coming out of the angled jets at their end or is the main circulating pump running ok?
Posted on Apr 02, 2007
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
SOURCE: middle arm of dishwasher not spinning
I'm the one that reported the same problem in November as "Guest". I fixed mine finally. I removed the middle arm again and noticed that the holes that spray a jet ot water causing the arm to turn aren't the ones on top. On the bottom of the arm there's a small hole at each end. I looked and one of the holes had a small piece of crud in it. I had to use the tip of an ice pick to dislodge it back into the arm. I then ran water into the arm several times hoping to get the item completely removed. I never did see anything come out but I then ran water through the arm holding it so the water could run out one end. The piece didn't show up in the hole again so I tried washing it to the other end. It still didn't show up so I guess it must have washed out the first time. It's been 3 or 4 weeks now and the arm is still functioning perfectly. Hard to believe that one little piece of trash can cause so much irritation. Good luck on this being the problem for others.
Posted on Jan 08, 2009
Kgt1962
  • 59 Answers
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Posted on Mar 11, 2009
Dishwasher model Whirlpool gu2700xtsb1 does not seem to get dishes clean and leaves a significant amount of soap around the dispenser area. How do I fix that?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenanceDishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Sep 12, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Whirlpool dish washer leaves grit and dirt on dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
May 03, 2011 | Whirlpool Dishwashers
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
Why dishes are not cleaned on top of dishwasher but the bottom dishes are cleaned
Dishwasher
How to Buy
heatman101
Feb 23, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool GU2455.... dishwasher. Top spray arm is not spinning. Lower arm appears to be moving but slowly. Dishes on the top rack do not get cleaned. They are wetted, but the arm doesn't appear to...
Dishwasher
How to Buy
heatman101
Jan 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes not coming out clean. Residue on dishes. Model DU850DWGB1,Serial FJ1510409
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Nov 23, 2010 | Whirlpool 24 in. DU850DWG Built-in...
Dishwasher is not cleaning dishes
heatman101
k
Apr 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Built-in dishwasher Model DU8700XB -O
Most dishwashers have a soil separator which separates the soil from the water while it's washing. When a wash cycle is over a valve opens in the separator to allow the soil to go down the drain. If it's not working properly the washer will leave a film or food particles on the dishes.
It's under the lower spray arm. Post your model number and I may can find a diagram for you. Dishwasher- Inside the doorjamb on the top, left or right. On the door edge top left or right. Portable models on the back.
Mar 22, 2010 | Dishwashers
My whirlpool quiet partner 2 is not working!!
heatman101
wert
May 02, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The upper sprayarm flows water but does not turn. Therefore dishes in upper rack are not geting cleaned.
i have a kenmore elite dishwasher model 665.16059400, i need a lower spray arm nut, nobody can find this part, i've been to sears and also to their on line parts department 3 times and have come up empty, the last time i was assured that the nut would be included with a new spray arm if i ordered one, it was not,i know the spray arm was made by whirlpool, is there anyone out there who knows the solution to this simple problem? does whirlpool have a cross referance model number i can use to find this part
Apr 29, 2009 | Dishwashers
Dishwashers Logo
128 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
