Question about Epson Stylus Photo R320 InkJet Printer
Stylus Photo R320 "printer driver dealing with CD printing...
I have an Epson Stylus Photo R320 that I've been using for years with my Macintosh G4 tower. I'm running Mac OSX 10.4.11. Suddenly, and after I had to reinstall the system software, the printer will no longer print to CD/DVD. Everything else works just fine. I've tried manually printing to disc, but every time I open the CD/DVD tray, the red warning light comes on and no printing takes place. I sure would appreciate any advice!
  • 1 more comment
  • jimtbishop Jun 06, 2008
    I keep getting the error that the driver for the print CD is not installed.  I've used this R320 for years but when I upgraded to Microsoft OSX 10.4.11 it stopped working
  • Anonymous Oct 24, 2008
    I have the Same problem only when the printer is connected Via network. when it's directly connected to my computer it works
  • Anonymous Nov 15, 2008
    I too, have experienced xlnt service from my Epson PHOTO R320 with my MAC G4.3.3 version.
    I upgraded to a MAC 10.4.6 version, and the 'ol trusty PHOTO R320 has never printed anything but the head cleaning read out MR2048.
    I reinstalled, Word, Panasonic fax, Epson scanner, Epson and printer... Printer does not print.
    It receives commands to print and goes through the motions and sounds, but does not print... NEW BLACK INK INSTALLED... still no print.
    Help!
    Walter
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
Posted on Sep 24, 2008
Thank you!!! Been fussing with this problem for some time! Apparently in Epson Print CD ver 1.5 the system changed drastically and needs additional drivers that come from the installation of EPSON EASY PRINT. If you install it as suggested above EVERYTHING now works wonderfully!
If you have the problem with the print being off centre use the NEWER version of Print CD will fix this.
My ver 1.2 would not print on my Epson 220 but 1.4 and 1.5 work fine!
Thanks again!
Posted on Nov 01, 2008
Installing Epson EasyPrintModule and it works :)
Posted on Jul 13, 2008
When you get the error hit ok and ok again and when you get to the window with the copies and pages pull down go to print settings and in media type you can choose cd/dvd.  then, if your unlucky like  me, your printer will start printing only all the images will be too small and off center.     And answer and a question!?
Posted on Jul 04, 2008
I have an Epson Stylus PHOTO R320, prints fine except when I try to print on a CD. I have windows 7 64 bit. I downloaded all the drivers for that and as I said it prints fine except when I want to p
My research shows that you must use special printable CD/DVD media which generally costs a bit more than nonprintable media. Possibly that is the reason. You don't give much info on what happens - if it feeds and the result is blurry I would think it is the media.
Jan 04, 2015 | Epson Stylus R320 Digital Photo Inkjet...
Mac OS 10.5 Leopard
you need to install Epson Easy Print too
Jan 15, 2009 | Epson Stylus Photo 2100 InkJet Printer
Epson Stylus Photo R320 - How to print to inside hole of DVD
In Epson Print CD program go to File ->Inner/Outer Diameter Settings. Set the inner diameter to the size you want.
Nov 22, 2008 | Epson Stylus Photo R320 InkJet Printer
The epson printer driver dealing with cd printing is not installed
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Oct 03, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus R320
Reinstall the printer drivers on your computer and then try to print.
May 15, 2008 | Epson Stylus Photo R320 InkJet Printer
New Canon Rebel xti photos won't print on my Epson Photo R320
Re-install the printer after downloading the latest driver from Epson. It is quite likely that the Canon software has over written the colour profile for the Epson.
Sep 16, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
2,137 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
