Question about Miller Trailblazer 302 Welder Generator 907217 907216
My trailblazer 302 has low output in a/c tig mode. if i set the amps at the max which is 213 the most i can get out of it is about 125 amps. it used to work fine . i have checked all of my leads and connectors , and tried using different remotes, i have also tried using a very short gound lead that is only about 10 ft long. none of this has made any difference. it works fine in d/c mode for stick and mig. the machine is about 5 years old. the problem started about 7 months ago and seems to keep getting worse.
  • 23 Answers
SOURCE: no gas flow
You never mentioned switching the polarity, this must be done when switching between wire types, Connect polarity appropriately, for steel use dual mix carbon dioxide/argon and set flow to 25-30 and give it shot. Good Luck!
Posted on Apr 22, 2009
luxur4
  • 92 Answers
SOURCE: i have an old mastercraft 110 volt ac stick welder
35 amp should do nicely however make sure the mains cable is of the correct size, better still, get a qualified Electricion to install it.
Usualy 30amp could be used but using 35amp gives you some reserve
Posted on Oct 09, 2009
luis_david
  • 407 Answers
SOURCE: mp 65e, how to change
Here's the link, check page 27 for right voltage connection.
http://www.millerwelds.com/om/o223aw_mil.pdf
Posted on Feb 05, 2011
  • 18 Answers
SOURCE: I have a lincoln 140 pro mig welder.I am useing 35
Your Linner of the gun could have a kink in it.
Posted on Feb 19, 2011
luis_david
  • 407 Answers
SOURCE: i have miller deltaweld 302 lead stays hot all
Hi:
The problem could reside on the contactor, this part due to the heat and constant contact (that is the noice you hear everytime you strike an arc) sometimes it remains close. Check your owners manual and it is the numbered 21 on the part list.
Good luck
Posted on Jul 13, 2011
Dim on headlight not working, changed fuse,bulb,relay 15016745,and bulb connector,still want work-2002 trailblazer
Low beam's don't work , how about high beams . Low beam relay is turned on by the BCM - body control module , headlamp switch is a input to the BCM . Your best bet mite be to take it to a qualified repair shop , rather then guessing an replacing parts you don't need . Hooking up a scan tool an checking for DTC'S - diagnostic trouble codes should have been the first step before replacing parts .
The headlamp driver module (HDM) is an electronic module that provides electrical power to the vehicle low beam headlamps. The HDM is controlled by a pulse width modulated (PWM) ground signal from the body control module (BCM). The BCM determines the desired lamp intensity using the ambient light sensor, multifunction switch , wiper motor, and the park brake switch as inputs. In general, the HDM will operate in one of three modes:
• Reduced Intensity Mode: This mode is used by features that do not require or allow maximum low beam headlamp intensity such as daytime running lights (DRL) (nominal: 81% duty cycle).
• Full Intensity Mode: This mode is used by features that require full low beam headlamp intensity such as low beam headlamp operation in manual, wiper activated headlamp (WAH), or auto modes (nominal: 100% duty cycle).
• Off Mode: This is the default mode of the system that will occur when none of the features described above are active. The BCM will deactivate its PWM output (0% duty cycle) during this mode.
Chevy Trailblazer headlights don work HDM input output testing YouTube
Aug 27, 2017 | Cars & Trucks
Konzert amplifier av 302
200 watts is the output, home use or commercial? not a good amp to run at its max as it has a low reserve headroom. for home use 100 watts rms is more than enough.
Mar 08, 2014 | Audio Players & Recorders
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Miller Trailblazer 302 Gas, will start but, but won't weld or generate. Does not show any readout on the digital meters, will not idle up, only idles at low RPM's. Any idea what may have...
Check the circuit breakers, one may have tripped or failed, such as CB4 which would also impact generator voltage output and since it controls power to the 24 control system- the first one to check or service. If you can access the rear terminals, check the voltage in operation at both lugs- if you do not get the same voltage reading at each lug of CB4 measuring them one at a time to chassis ground, the breaker is tripped or faulty .
CB1 is inline with the 240 VAC outlet and is ahead of CB2 and CB3
CB2 and CB3 are inline with the 120VAC outlets
In each case, switch them off then back on.
If you have the GFCI option, it may have been tripped by unsafe conditions.
Sep 20, 2011 | Miller Trailblazer 302 Welder Generator...
I need the part number for the termial output and ground for my 302 diesel Trailblazer and a part number for the starter motor for my 400P Big Blue Diesel. Also any suggestions on spare parts I should...
Hi:
Part number for the ground output terminal is MIL 039046, list price is $24.34.
For the Big Blue need to specify what engine/model does your machine has or serial number.
Aug 07, 2011 | Miller Trailblazer 302 Welder Generator...
Linde welding machine when welding in tig mode foot pedal will not control amphere output it goes from 0- 100 no in between
Check to see if the remote switch has been set, or if you have broken wire in your pedal lead. You might even want to open the pedal housing and take a look see. I've had more than my fair share that the contacts inside the pedal housing were worn or cooked. Good luck, hope it helps
Sep 03, 2009 | Welding Tools
Max. VOLUME on Samsung TVs Too Low
Some models have a volume limit setting, check the MENU and look at the audio settings.
If this has external speakers use other speakers. If it has audio output connect them to a external amp and useing the remote adjust the volume. Check if audio settings are set to internal, external and fixed or vairable output.
Jan 09, 2009 | Samsung LN19A451C LCD TV
TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Aug 27, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Miller Trailblazer 302 Welder Generator 907217 907216 Logo
153 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
